![]() ![]() Drives: 2013 yaris Join Date: Sep 2014
help adding a sub?
i want to install a amp and sub but have never done it any help?
![]() Drives: Yaris 2015 1.5G Join Date: Aug 2014
yes I did today :P. I have put a 2000w peak 400w rated Sony XS-GTR121L subwoofer 12inch with a Pioneer gm-d8601 amplifier. What i also did was install a switch in a sense that I can turn on or off the sub whenever i want to listen to the music without it. If you need pictures of the setup not a problem ;)
yes please
First thing, sorry it took me time to get you the pics. I got very busy.
Things you should notice, the first picture shows the connection an idiot did, what he did was take a live connection from the battery to the amp without taking a connection from the stereo (it is the U connection in the picture). What this resulted is even when i turn the car off the amp stays on. I learnt the hard way after trying to turn the car on and it didnt. Took it to another guy to check it out, he laid another cable (which the first guy didnt) from the amp to the stereo so once the ignition/contact is on the amp goes on, acts like a switch. I donno about your stereo or how its done in your area but here, they put a fuse for the amp on the positive connection. I took a picture of it. Lastly, i didnt have time to take a picture but for factory stereo, they use an adapter. If you want more detailed pictures I can arrange that of the amp (because i took the pics at night bad focus) or the adapter. Not a problem. I hope these help |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
use the search function for "Amplifier" and one of the results is:
http://www.yarisworld.com/forums/sho...ight=amplifier |
Roadrunner Jr.
The remote wire is important. You also need to be aware that when you use more than two amplifiers, get a relay for the remote turn on duties. That'll protect the source if there's a short.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
My setup is only 1 amp for 1 sub.. enough bass for daily driving or cruising. U suggest i also add a relay? Is that a fuse or? Explain further please..
![]() ![]() ![]() Drives: yaris Join Date: Oct 2008
If you have never installed a sub or an amp, you may need a little more help than a few pics on a forum. If you don't really have a knowledge of car audio, I suggest getting help or doing some much more in depth research.
ballin on a budget. |
| Adding USB ports for charging | mr_miles | DIY / Maintenance / Service | 7 | 01-16-2012 03:48 PM |
| DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS | julienrl | DIY / Maintenance / Service | 1 | 08-31-2009 10:06 AM |
| Adding Cruise | otterhere | Performance Modifications | 1 | 11-24-2008 04:11 PM |
| adding an Amp | Keymaster | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 02-16-2007 06:09 PM |
| adding DRL's..?? | static808 | DIY / Maintenance / Service | 9 | 10-20-2006 04:15 AM |
