Old 02-15-2007, 11:24 AM   #1
Keymaster
Drives: Yaris '06 1300cc
adding an Amp
Well i'd like to add an amp in stock headunit can i take the signal from the rear speakers from the back of the headunit (strip the cables and adding an LOC there) and from there to the amp? or i have to strip the cables near to the speakers and connect from there the LOC (low output converter)?
Keymaster is offline   Reply With Quote
Old 02-15-2007, 01:01 PM   #2
Kitt
Kitt's Avatar
IMHO I won't recommend doing it on the stock unit... get an after marked one with pre-amp out... just my 2 cents...
Old 02-16-2007, 10:44 AM   #3
Keymaster
And if i do this in the head unit can this that i'm telling going to work???
Old 02-16-2007, 12:16 PM   #4
spkrman
Drives: 1
its the same signal behind the head unit as at the speakers.
Go with behind the head unit, it'll make your life alot easier.
Old 02-16-2007, 03:19 PM   #5
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
You can also splice into the rear deck speakers since the amp is right there if thats were you are going to mount it. U can save alot of money on RCA's and you also have room to tinker with it. I always liked to put it in the rear, but the choices of were to install are limitless.
Old 02-16-2007, 06:09 PM   #6
Keymaster
Thank's a lot for your answers!!
amp wiring question... Keymaster In Car Entertainment + Electronics (audio / video / alarm) 3 02-03-2007 10:01 AM
Power acoustik 2400db - 1800w amp! CHEAP! + 12" sealed spkrman Items for Sale by private party 1 11-27-2006 02:02 PM
Would you like an Amp to go with that?? Terrorize In Car Entertainment + Electronics (audio / video / alarm) 2 07-10-2006 04:51 AM
