Old 05-12-2012, 12:23 AM   #1
Hershey
Exclamation 2012 Toyota oil chart : What the ...
!!! Looks like it states 5w-30 non synthetic only . A bit misleading since there was the TSB EG018-6 giving approval for 5w-20 . Have a signed approval of that from a Toyota service center and from the corporate headquarters in California . There's also a chart for Canada that gives approval for 5w-20 and 0w-20 , http://pdfcast.org/pdf/toyota-oil-recommendation . You'd think they'd be the same since it's the same 1.5 ltr. engine . Does this mean if there's an issue with the engine that they could void the warranty by discovering use of a 5w-30 or lighter synthetic oil ? Here's the chart , http://www.bobistheoilguy.com/forums...29#Post2624429 . Is this legit ?
Old 05-12-2012, 12:32 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Synthetic has higher tolerances that conventional anyway. I ran 5-20 in my motor from my first 5k change and the inside of mine looks clean as hell.
Old 05-12-2012, 12:50 AM   #3
2007yariz
Drives: Yaris sedan
I saw that also tonight.
5W30 will sheer down to 5w20 anyways, so i always used 5w30.
Nice find hershey! Now i can acutally see it clearly.
2007yariz is offline   Reply With Quote
Old 05-12-2012, 01:30 AM   #4
Hershey
Just found this better reference chart, http://wms.tkcarsites.com/PagesOnThe...Type%20V12.pdf . We've been using synthetic since around 15k.
Old 05-12-2012, 01:50 AM   #5
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Wow...
Thanks for the useful information, Hershey.
The question now is why no synthetic oil in the Yaris?
Just checked my 2012 owners manual and it specifies SAE 5W-30 like the other years and says nothing about synthetic.
Old 12-28-2013, 01:40 PM   #6
snailmailmike
Drives: 2012 Toyota Yaris
5W20 or 5W30?
The manual for my 2012 yaris calls for 5W20 but the filler cap says 5W30. Does it matter if I use 5W20 or 5W30?
Originally Posted by tooter View Post
Wow...
snailmailmike is offline   Reply With Quote
Old 12-28-2013, 02:43 PM   #7
fnkngrv
fnkngrv's Avatar
It really depends on the climate you reside in and the time of year. Here is a decent article on what the nomenclature means:
Choose the right oil
Old 05-12-2012, 01:57 AM   #8
TOLMACH
Drives: soarer
WHAAAAAAAAAT ?????????
Why no synthetic is allowed ??????????
Old 05-12-2012, 08:58 AM   #9
Happy Little Pony
Drives: 2007 Yaris HB
They probably want the repair shops to use the cheaper conventional oil in a customer's car and to not sell them the more expensive synthetic. A five thousand mile oil change with conventional is more than adequate; the synthetic really is overkill.
As to only specifying 5w30, if you were only going to recommend one grade of oil that worked everywhere and was the most common grade available in most places, 5w30 would be what you'd say.
Happy Little Pony is offline   Reply With Quote
Old 05-13-2012, 01:06 AM   #10
LukeJone
Drives: NOne
It is an oil fill chart, meant to be used by people servicing the cars. They probably list them as conventional only, as not to not cause so much confusion.
Escorts Aberdeen
LukeJone is offline   Reply With Quote
Old 05-21-2012, 09:00 PM   #11
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
i heard toyota has gone to synthetic oil in there cars and claims to change it every 10,000 miles anyone ever hear this ?
pennyracer is offline   Reply With Quote
Old 05-21-2012, 09:19 PM   #12
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
i honestly was very worried about waiting 5 thousand miles for the first oil change, but apparently thats the correct way to go nowadays with newer cars.
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline   Reply With Quote
Old 05-23-2012, 06:00 PM   #13
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I don't think anyone should wait that long for the first one. But supposedly nowadays all the traditional engine breaking in is done at the factory.
Colin Chapman disciple
Old 05-24-2012, 01:38 AM   #14
fnkngrv
fnkngrv's Avatar
That is a small part of it. The oil companies have been lining the manufacturer's pockets for decades. Perhaps you have heard of the engine created over 50 years ago that was able to get much more than what the Prius does today back then? The information and evidence was bought by a major player in the industry because at the time oil was dirt cheap as it was along with plenty of other reasons that they found to be a threat.
If you take a look at the technology today in oil refinement or at least what is being advertised is that the processes and additives are strengthening the end product to the point that it can last longer. Also of course engine efficiency has been increased dramatically.
Sure, I am championing AMSOIL, but also I have run Mobil 1, Royal Purple, Penzoil Synth, etc mainly because it has been proven to not only give you longer drain intervals, but better pour temps and lower engine temps/wear patterns. I personally didn't hesitate in the least to go the 5k that Toyota's blend called for on the initial change.
As previously stated you can use what you wish for lubricants. If the engine fails and the manufacturer wants to not warranty it then they have to do all of the homework to prove that what you placed in your crankcase was directly related to the failure of the parts.
Old 06-14-2012, 08:52 AM   #15
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Hello everyone. Question. My car was lighted lamp oil change. Changed oil and oil filter. Mobil1 synthetic oil 5w50. The lamp is not extinguished. We need your advice?
I like very much travel
MickZEL is offline   Reply With Quote
Old 06-14-2012, 01:22 PM   #16
BLH
Drives: 2007 Yaris Sedan
http://www.yarisworld.com/forums/showthread.php?t=3940
BLH is offline   Reply With Quote
Old 06-14-2012, 03:42 PM   #17
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Thank you for your help. All done.
Old 01-16-2014, 03:04 PM   #18
alexis rodriguez
Drives: Toyota Yaris 2005 HB
Hello I am from Panama.
At 30°C on my country. Can i use 10W 30 oil on my Yaris HB 2005 1.3?.
thank you
alexis rodriguez is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 09:43 PM
2012 Toyota Yaris alarm tonyc1234 DIY / Maintenance / Service 0 05-04-2012 04:29 AM
F/S 2 TUBES OF TOYOTA FIPG SEAL PACKING FOR ENGINE OIL, P/N 00295-00103 mehullica Items for Sale by private party 0 06-12-2011 08:10 PM
Toyota Oil Specs Chart sbergman27 General Yaris / Vitz Discussion 7 04-20-2011 10:02 AM
