Old 04-17-2011, 03:20 PM   #1
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Toyota Oil Specs Chart
This is probably old news here, by now. I haven't been monitoring the forum. But I figured I'd post this just in case. If this is correct, 0w20 is now retroactively spec'd all the way back to the Echo. And 5w20 even back to 1995 for many Toyotas. I will note that this link is to clublexus.com and not to toyota.com. And as I just discovered it, I haven't had a chance to check it out.
http://www.clublexus.com/forums/atta...plications.pdf
-Steve
sbergman27 is offline   Reply With Quote
Old 04-17-2011, 03:27 PM   #2
jonathankoji
jonathankoji's Avatar
Drives: 08 Yaris S Sedan
What are the benefits of running 5W-20/0W-20?
jonathankoji is offline   Reply With Quote
Old 04-17-2011, 03:33 PM   #3
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
Better mpg?
DMZ is offline   Reply With Quote
Old 04-17-2011, 03:39 PM   #4
sbergman27
sbergman27's Avatar
1% - 2% on fuel economy. Plus, the current crop of 0w20s like M1 and Toyota's Genuine 0w20 appear to be excellent oils, judging from the UOA's I've seen.
New Prius owners, and others with cars which now *require* 0w20, get the benefit of (officially recommended) 10,000 mile oil change intervals.
-Steve
Old 04-18-2011, 10:13 PM   #5
thepartsmancometh
Drives: '08 LB, '07 WRX
in the shop, we only use the 0w20 on the required applications. The price seems to drive most others off. It isn't cheap, the genuine "Toyota" 0w20 is actually ENEOS brand (made by Nippon Oil), and retails for $6.66 per Toyota. People with a choice of $3 per quart or $7 per quart tend to pick $3
thepartsmancometh is offline   Reply With Quote
Old 04-18-2011, 10:51 PM   #6
auxmike
auxmike's Avatar
I'll stick with 5W30.
If it ain't broke,don't fix it...
Old 04-19-2011, 08:27 AM   #7
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Anybody have an idea where to get Amsoil 0W-30 for a little cheaper that $10? I'd like to try it, but if I can't find any cheaper than that, I'll be sticking with Royal Purple 5W-20 for less than $8...
goliath1812 is offline   Reply With Quote
Old 04-20-2011, 09:02 AM   #8
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
If you join Amsoil's preferred program for $20 a year you get wholesale prices. First time you can buy a 6 month trial to the preferred plan for $10. Amsoil SAE 0W-30 Signature Series (their best, good for 25K normal/15K severe) is $7.70 a quart (versus $9.95) and if you buy a 12 quart case it's $7.29 a qt (versus $9.84). I use this in my Yaris and my wife's 2004 Elantra. I also use Amsoil's Absolute Efficiency Oil Filters that are good for 15K in normal to severe service. The one for the Yaris is $10.85 (Versus $14.35).
Here is a place that has motor oil comparisons with all properties:
http://themotoroilevaluator.com
rick996 is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
Dealership filled engine with too much oil... posaunemeister DIY / Maintenance / Service 17 10-18-2009 11:21 PM
