DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads
MOVED
I don't mean to be rude or anything but when you said you don't have to bleed the brakes, you still have to no matter what when you do something like this to your brakes. I've been through two years of auto but i'm still a noob. All we did in that class was dis-assemble American engines *shivers* and re-assemble them and then we moved on to oil changes and brake pad swaps. Still good DIY though
#4 | |
Haha I'm still a noob also man. Bleeding the brakes is a PITA though. But if you were in contact with Dezod I'm pretty sure they know what they're doing but it might be a nice idea to get those bubbles out of the brake fluid and bleed them though. Still a clean install compared to when I did my first brake replacements.
der Zeck
Oh and for god sakes get some wheels Chino! Nice DIY, and one of your screwdrivers is still in the back of my car.
#8 | |
But seriosuly, folks, nice writeup, very detailed, anyone should be able to follow these instructions!
I have to say NO.
ABS or not, the brakes do not need to get bleed for a brake PAD swap. Especially in this case where is not a 25,000 miles car getting pads. I would suggest opening the brake fluid cap first though, before compressing the piston back in the caliper.. makes it a bit easier. |
#10 | |
so you can place a CLEAN rag on the top of the reservoir to soak up the extra fluid. |
Awesome DIY!
The Scion Guru
Drives: Scions Join Date: Feb 2007
Great DIY Charles. You're such an asset to the community. BTW, I told you would feel a tremendous response difference in braking.
Dezod Motorsports Inc-'We ARE performance." P: 716-681-6666 E: sales@dezod.com W: www.dezod.com Your leading source for all of your performance needs! From turbos and components, to brakes and suspension, Dezod has you covered. |
welp I did say I'm still a noob though =P
I'll edit the DIY with the new info. Thanks for the clarification Chris! Basically, if you do have trouble getting the assembly back on you can remove the bleeder cap and use a C clamp or something comparable to depress the piston. For the record, it was a snug fit but mine went back on without having to do this.
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
When doing a standard brake service (r&r pads & cut rotors) we do not bleed the brakes. It was the same when I worked for Honda and Acura, as well.
I'm sure though, being the 148975616478964564th person to point this out, that it's probably just pissing you off at this point.
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
#16 | |
Let's see. If I remember correctly, repeated information gets to people faster than information stated once =P
The Scion Guru
Where's the review Charles?
Well, today I went outside and took all of my clothes off and built a bonfire. I began chanting in something that sounded to be of a West African origin, but nobody could really tell. After about an hour I realized I cannot drive rain clouds away by speaking to trees and went back inside.
58 and partly cloudy this Sunday.
| Big Brake kits for Yaris 5 door | mojoyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 03-23-2007 12:30 AM |
