Old 04-28-2007, 08:10 PM   #1
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Yaris T-Sport is offline   Reply With Quote
Old 04-28-2007, 09:39 PM   #2
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
if there is not much missing - say less than 1/8 of a gallon, refill with distillate water
hystria is offline   Reply With Quote
Old 04-28-2007, 10:37 PM   #3
GuySmily
GuySmily's Avatar
Drives: 2005 Toyota MR2
I'd recommend to buy just one bottle of red Toyota coolant for top-offs, and when you do your first coolant flush, you can switch to something else.
In my mr2, I use Prestone All Makes/All Models coolant. It is silicate-free, like Toyota coolant, which is the main difference from normal coolant.
The prestone stuff is green though. If you mix red and green you get a nasty brown... Which is why I say to buy a bottle of red stuff for now.
Someone on mr2oc posted this response they got from Toyota regarding coolant choices:
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
Toyota recommends using Toyota Super Long Life Coolant or similar high quality ethylene glycol based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology. Use of improper coolants may damage your engine cooling system.
GuySmily is offline   Reply With Quote
Old 04-29-2007, 12:09 AM   #4
Pars
Drives: 07 Yaris Liftback
In my old Civic, the reservoir tank simply slid off so that you can poor it back into the radiator. But if I were you, I wouldn't screw around, just get the Toyota coolant and fill the thing back up asap. ruining your head gasket cause you want to save $20 is dumb.
You shouldn't have drove it in the first place with low coolant. It's ok to drive with low reservoir, but if it's missing in the radiator, it's a no drive situation. Now, you've probably introduced air into the cooling system and hopefully the Yaris coolant system can do a good job to compensate for that. But from experience with small engines (Honda), it doesn't take much to kill the engine once the coolant gets messed up.
Pars is offline   Reply With Quote
Old 04-29-2007, 12:40 AM   #5
churp
Clean and (dis)Functional
churp's Avatar
The reservoir 'never' drains to the radiator...when the water gets warm it expands and goes to the res from the radiator, only when the water cools and shrinks does it 'suck the coolant from the res to the radiator. Without water in the radiator you can ruin the engine easily. It may take many cycles for the radiator to 'suck' enough coolant back into it, please put coolant in the radiator----foolish not to.
____________
Old School Cobble Jockey
Old 04-29-2007, 05:31 AM   #6
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
Thumbs up 99cents vs 20bucks...easy choice
x2...99 cents a gallon...better cooling properties than anti-freeze...just make sure it's "distilled" and not "mineral"...
another idea would be to add a product called Waterwetter. It works by lowering the viscosity of your coolant system which prevents cavitation (bubbles)...It costs about $7-10...
http://www.redlineoil.com/products_coolant.asp
fu_im_from_texas is offline   Reply With Quote
Old 04-29-2007, 10:42 AM   #7
MrJester
Drives: homo
just about any grocery store or Walmart.
MrJester is offline   Reply With Quote
Old 04-30-2007, 01:45 AM   #8
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Don't dilute your coolant with distilled water if you don't know how much is missing. $20 for a gallon of Toyota coolant vs. $20,000 if you over dilute it and it doesn't maintain it's freeze point next winter. Don't gamble with your new TS, we all want one and would hate to see anything bad happen to it. Are you ready for an oil change? Get a service done at your dealer and they should top all your fluids off.
Gas pedal problem? Befuddled Performance Modifications 28 01-27-2010 10:55 AM
Electronic Trunk Release Problem jonr0613 DIY / Maintenance / Service 5 09-08-2007 07:13 AM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 07:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 10:12 PM
no tach= problem for newb? BrownNBubbly General Yaris / Vitz Discussion 19 05-18-2006 03:16 PM
