Old 07-08-2015, 11:53 AM   #1
dark_seek
Drives: yaris 2013 (LE)
195/50/16
Will 195/50/16 fit yaris 2013 LE model ?
Kindly give your reviews
dark_seek is offline   Reply With Quote
Old 07-08-2015, 12:16 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes. In fact in the US that tire size is standard on the SE model.
NYC-SE is online now   Reply With Quote
Old 07-08-2015, 12:22 PM   #3
dark_seek
Isn't there some difference between the LE and SE
I guess 16's will fit both then .
Thanks anyways
Appreciated
Old 07-08-2015, 12:26 PM   #4
NYC-SE
NYC-SE's Avatar
Thanks anyways
Appreciated
The SE has 4 wheels discs and the front discs are slightly bigger than the LE model. Also different suspension tunings. But none of that affects the tires. Of course you need 16" wheels as well as the tires. LE wheels are 15" stock.
Old 07-08-2015, 12:28 PM   #5
dark_seek
Thanks man ^^
I was really confused
Old 07-08-2015, 12:51 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
195/50/16 is a JDM OEM fitment.
* Many folks fit 205/50/16's because they are a more common size offering more brand options. 205/50/16's work very well on the car.
Old 07-09-2015, 06:56 PM   #7
dark_seek
205/50/16 might rub on full turn i think
Old 07-09-2015, 07:16 PM   #8
kimona
kimona's Avatar
I run 205/50/16 on 16x7, ET42. No rub on full turn with current tyres.
But even 195/50/16's can rub on full turn. Minor inside rubbing on full turn is not a big deal.
Old 07-10-2015, 12:41 PM   #9
dark_seek
Yeah thanks for help
Old 07-10-2015, 03:04 PM   #10
Once again, it is all about the offset.
Old 09-22-2015, 04:50 PM   #11
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Is it best to go with a 16 x 6.5 (versus 16 x 7.0+) aftermarket alloy wheel for my 2015 SE, if I plan to stick with 195/50/16 or 205/50/16 tires? I assume the lighter weight of the 16 x 6.5 wheel would be preferable, and closer to the OEM 16 x 6.0 wheel sizing. All the designs that I like (located in the U.K.) are x 6.5 or x 7.0 sizes only, so OEM x 6.0 isn't even an option.
What offset should I be looking for with those wheel/tire sizes?
On a side note, Tire Rack (and U.S. Distributors) seems to have a very limited selection of conventional/traditional wheel styles, compared to various U.K. alloy wheel stores. It looks like I will have to pay for international shipping rates to get the wheels I like.
Kalispel is offline   Reply With Quote
Which way i go? I will be on 16x7.5 +35mm rim. Will i be on 205/50/16 or 195/50/16 daddz07 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-15-2014 02:12 AM
FS(NJ): Lightly used 195/50/16 Bridgestone Turanzas NJ Drive Items for Sale by private party 16 05-29-2013 02:22 AM
Summer Tires 195/50/16 (2) Options? derickveliz2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 04-01-2013 01:57 PM
16x7 - 40mm offset - 195/50/16 rubbing like a fat kid at a Rave 3cyltrbo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 04-14-2011 03:42 PM
195/50/16 or 205/40/17? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 10-18-2009 05:17 AM
