![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
195/60-15?
Needing to replace my tires and the stock size for the Yaris is rediculously expsenive. The 195 size is wayyyy cheaper in price but I don't know if it would be a good replacement size or not. I'm running Tokicos and Tein stech springs.
Any suggestions on what would be a good replacement for stock rim size and my suspension setup?
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
I believe 195/60/15's actually fit much better than OEM 185's on stock suspension.
How about for my lowered setup? Is it still ok to run them?
#5 | |
play every day
Thanks for the replies so far, I'm still trying to figure out if a 195/60/15 will be ok on a lowered setup though?
#7 | |
Logan
Drives: 2009 Yaris Liftback Base MT Join Date: Jan 2015
You should be fine. I am on Tanabe DF210s which is about a two inch drop. I have been currently running 195-60-15 tires. There has been no rubbing for as long as I have had them (5 months.) Good luck in your tire search. |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
I'm sure he's fine, it's been three years this thread was posted in! lol
intern
Drives: 2007 yaris 4 dr sedan Join Date: Jul 2015
let's hope so! i'm very happy with the 195/60/15's and TRD rear sway.
2007 nautical blue sedan, 5 spd, TRD PTR11-52071, TRD PTR03-52080, K&N drop-in. |
Form>Function
If you are not changing wheels measure about 10 mm out from the sidewall and see if that point still clears you fenders.
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
What are the prices like on a 195x55x15. I suspect 60 may rub with Teins.
Form>Function
I ran 185/60/15s slammed on megan coilovers with no rubbing.
Mr. 155 and climbing
It all depends on what you are truly asking, but you should be fine. I have just taken a bunch of photos for you with my stock 15" steelies and my Winterforce 195/60s. I am running 2" drop front and 2.25" on the rears with my AMRs. I just drove over to an autocross event and there was a couple places where I kid you not they had torn out 2-3' sections of the road for repair of something and the patch area where they had worked was about 3-5" deep! I didn't rub. I can't really give you a full turn radius opinion because my 18s totally shredded my plastic panels, but when I did have them in place I never recalled rubbing on full radius turns nor on the roadways with even serious dips/pothole hazards.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Remember too that winter tires tend to protrude more a the edges, etc than summer or all seasons. I hope that this helps at least a little even though I am running different springs.
#14 | |
It is the JDM thing to do, plus it protects where there is bare metal at least a little. I still can't figure out how the hit n run managed the weird type of damage that occurred. My door doesn't have a dent for damage yet the doorjam on the body does...it is like the thin sheet metal of the door must have flexed.
Yaris_Ninja
Drives: 2009 Yaris 5Door Hatchback Join Date: Aug 2010
You should have no rubbing issues. i have Tein S lowering springs that dropped my yaris 2inches all around. when i did drop my yaris i had the 18in TRD rims and they had 215/35-18 tires on them. they were rubbing alot but thats cause the overall diamater is about 3/4inch bigger. they mainly rubbed on the fender liner. i took them off and put the stock steelies and tires on and no rubbing at all. i would drive my yaris hard and it would bottom out at all. the only thing i had to be careful of was speed bumps lol. I currently have the 18inch wheels back on after i had new tires installed. I had to cut most of the liner put and rolled the front fenders myself. they still rub on the remaining liner so i am going to end up removing the liner completely. so yeah dont worry.
intern
I felt much better about 195's after seeing your pics. off the car they look huge. the wheel cover makes the 185's look smaller....lol. pics soon
I never liked the 195/60's on the yaris. The car sits 1/2" higher.
Sent from my A0001 using Tapatalk |
