![]() ![]() Drives: 2010 Yaris 2dr 5spd Join Date: Jan 2015
Rust on transmission
There is some rust on the top of my transmission. I'm guessing it was caused by the horrible battery corrosion that happened with the previous owner.
How concerned should I be about this? I made sure to wash the area in baking soda and water. Tip: When buying a used car, always inspect the car thoroughly, and always do it during the day. I didn't discover the broken radio antenna and battery corrosion until days after I bought the car from the dealer. |
It shouldn't be an issue, as long as the corrosion did not get into the switch assembly that the shift lever moves.
I guess theres no dealer warranty?
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 10:07 PM |
| My 2010 yaris is on its 4th transmission!! Help please | Uzairlexus | DIY / Maintenance / Service | 12 | 07-16-2013 11:46 PM |
| need experts helo on robotic transmission clutch | mariann | DIY / Maintenance / Service | 0 | 10-03-2012 01:51 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
