Old 10-03-2012, 01:51 PM   #1
mariann
Drives: yaris 2007
need experts helo on robotic transmission clutch
i have reachd 125000Km with my 2007 yaris.
it have robotic transmission.
i think the cluch is starting to slip under hard load.
first of all it acting wierd and its not slipping al the time. and when it slips sometime a moment later its chatching back the flywheel by itsalf... i think the cluch getting loose.
anyway... tomorow morning i'll change my clutch for 950$ at the dealership.
outside the dealership replacement clutch and work will not reach more then 350$.... but as far as i know they cant reset the robotic transmission without the toyota computer...
is there any way you know guys to reset the gear without connecting the service computer?
is it the time to change clutch for robotic transmission or its a computer problem?
with normal maual transmission its easey to check if the clutch is slipping, but i dont know how to check with robotic transmission exept of loading the engine on the third gear and stick accelerator till the end and watch if the RPM rising without pulling the weels accordinly.
thanks.
mariann is offline   Reply With Quote
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
