Old 08-11-2013, 12:57 AM   #1
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Disable panic alarm on key fob.
I have a 2007 Yaris HB RS model with power locks / panic alarm on the fob ... and I was wondering if it is possible to disable the "Panic Alarm" feature. It has gone off accidentally on me a couple of times and my neighbors don't appreciate it.
So .. can I get this panic alarm disabled ?
edmscan is offline   Reply With Quote
Old 08-11-2013, 08:51 AM   #2
You can't disable it programatically, but the trick I use is to pop open the remote and stick a piece of tape on the circuit bard where the pad for the panic button would make contact.
Old 08-11-2013, 08:18 PM   #3
edmscan
edmscan's Avatar
Thanks for the reply, it is appreciated .. I will see about making the change. All I know is that my neighbors will be happier as it has gone off twice by accident. I am just amazed at the range that the fob has.
Old 08-12-2013, 10:21 PM   #4
Revsson
How does that compare to going off at 3:30 am in an underground parking garage?
Nobody complained....that I know of.... It's happened to me twice, too.
Usually when my hands are full and fumbling with the fob. Thankfully, I don't have to
work those early hours too often.
Old 08-26-2013, 08:17 AM   #5
Sorry guys. My Yaris don't have the OEM fob, so I was going by the last one that I did this with, which was on my 04 Xterra. I just took apart a Yaris key and the membrane is sealed to the plastic body on the internal mechanism, so you can't do my tape method. You can simply remove the red panic button or snip the nub off the back of it, or crazy glue it to the body.
Old 08-27-2013, 01:47 AM   #6
edmscan
edmscan's Avatar
Attachment 51678
Thanks for your response. I will keep this in mind going forward.
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Is there a panic alarm timeout ? edmscan DIY / Maintenance / Service 0 10-04-2012 10:52 PM
'08 Yaris Program Key Fob (Dealer installed alarm) jrollf In Car Entertainment + Electronics (audio / video / alarm) 2 08-12-2011 02:42 PM
Key fob locks but won't unlock Pingouin DIY / Maintenance / Service 2 09-15-2010 03:53 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
