Old 09-15-2010, 03:21 AM   #1
Pingouin
Key fob locks but won't unlock
Hi all,
A new problem developed on my 3dr 2008 Yaris this morning: although the key fob can lock the doors, it won't unlock them. I tried the spare fob, and it did the same. After many attempts, it may successfully unlock once in a while. The inside button does work though, and I can still unlock the driver's door with the key. I thought it could be the fob battery, but then the lock button always work, and unlocks is really struggling to work even when using the fob inside the vehicle. Besides, the little red light on the fob works fine.
Any ideas what could be wrong? It's still under warranty, but since it seems to work randomly, I bet that if I go to the garage it will work, they'll tell me that they can't fix something that works and I'll be wasting my time.
*EDIT* it seems that if I point the remote from the front window towards the back of the vehicle, the likelihood of the fob successfully unlocking the doors increases significantly, so I may try to change the fob battery anyway, albeit as I said before locking is working fine.
Pingouin is offline   Reply With Quote
Old 09-15-2010, 03:29 PM   #2
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
[QUOTE=
*EDIT* it seems that if I point the remote from the front window towards the back of the vehicle, the likelihood of the fob successfully unlocking the doors increases significantly, so I may try to change the fob battery anyway, albeit as I said before locking is working fine.[/QUOTE]
Shucks Auto has a keyfob remote tester on their counter (most locations) and it will analyze the fob transmitter's signal to see wheather your battery is bad/weak. For those that visit them, test your keyfob transmitter so that you won't have the same prob. I did while waiting for my reciept, and bought batteries while I was there, saving a trip for batteries. (only 2 years old)
I had the same issue and the batteries were not up-to-par and replacement corrected the problem on BOTH of my keys.....
bobolinko is offline   Reply With Quote
Old 09-15-2010, 03:53 PM   #3
Pingouin
Thanks bobolinko for the reply!
Yep, I switched the battery with a spare one I had lying around and it sorted the problem. Strangely, my other fob didn't seem to work either (which led me to believe that it wasn't the battery since I never use the other fob), and it worked when I got back home tonight
Still strange that locking was working fine. Also, the "dead" battery I removed is still at about 80% charge, so be weary that if it seems fine, it might still have insufficient juice!
Key Fob no longer Unlocking Boot Dixie DIY / Maintenance / Service 5 09-17-2010 12:18 PM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
Information needed about adding a additional key fob remote. YarisSedan DIY / Maintenance / Service 9 01-10-2009 12:09 PM
Flip Key FOB Kaeon Photo-Video-Media Gallery 28 10-01-2007 07:10 PM
