2ndary O2 Sensore plug in
When I was painting my exhaust the other day I noticed that the secondary O2 sensor right after the cat goes up into the body of the car through a rubber grommet.
Does anyone know where the heck you access where it connects to in case one ever needed to disconnect it?
Yes. The connector for it is mounted just behind the AC control panel on the driver's side of the center console. It is actually mounted to the vertical support for the dash there. You can get at it by pulling the carpet away and reaching between the AC box and the center console.
Thanks Scott, any chance you have an image of the specific area to look for the connector? I have the general area in my mind that you're talking about but I can't picture exactly what your talking about
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 03:12 PM |
| Wires Inside the Yaris & What They Do | The Architect | DIY / Maintenance / Service | 149 | 10-18-2022 04:32 AM |
| bit of spark plug insulation may have fallen into cylinder | alagappan the proud | DIY / Maintenance / Service | 20 | 01-09-2014 07:10 PM |
| Function of square plug near 12v. plug! | RS-Yaris | General Yaris / Vitz Discussion | 2 | 11-22-2011 09:16 PM |
| Plug Gap | slvryaris | DIY / Maintenance / Service | 1 | 12-23-2008 11:02 PM |
