Old 01-30-2016, 10:08 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
E85 Motor Build II
sorry for lagging..i finally completed the E85 conversion with ECU tuning..here are the list
-1JZ injectors (increase cc)
-E85 plug that goes behind 1JZ injectors
-Timing advance/ignition ECU
-Street tuned
**additonal mod before i had the E85 ECU tuning (recommanded by the ecu tuners)
-Header
-Center pipe
-NGK IX spark plugs
-C coded MAF sensor
-VVTI solenoid from RS Yaris/Vitz
-K&N drop in
im missing RS Yaris/Vitz Coilpack..
additional mod
-volt stablizer
-front top and rear low braces
my tires are spinning on every gear and brake pads cannot grip..FML..
some sticky Hankook tires and project Mu pads next week...
0-60mph time
stock: 12 sec
now: some where within the late 8 sec range..i think new set of tires can improve this issue..my butt dynos telling me i gained about decent 30-40hp from mod above..not WHP!!
future modfication
-sticky hankook tires
-project mu brake pads
-coilover or spring
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 02-10-2016, 11:22 AM   #2
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
how much did it cost for E85 build parts & tuning?
Fluxtasy is offline   Reply With Quote
Old 02-12-2016, 10:18 PM   #3
rabbito
rabbito's Avatar
1jz injectors: $60
E85 converter: i think he gave it to me free
Chip: $200 (i wanted a brand called Racestreet that comes with 2 step and a gauge but its sold out everywhere, i just got any ecu with same software program as Racestreet ECU)
Tuning: dont remember but i remember giving him $50 tip
Spark plugs: $60 (IX)
C Coded MAF and RS Solenoid: i think about $60
need RS coils to complete the set up...
Old 02-10-2016, 04:18 PM   #4
crazylegs
Drives: 2007 Yaris
so converting the yaris to e85 gas can give you some serious performance gains
crazylegs is offline   Reply With Quote
Old 02-12-2016, 10:27 PM   #5
rabbito
rabbito's Avatar
i dont consider it as serious power because its barely a stage 1 set up..the car is slow as hell, 110hp stock with vvti whining through out the rpm...
now it just became a decent passenger car
Old 02-14-2016, 11:36 AM   #6
crazylegs
Drives: 2007 Yaris
estimating 30% gains is pretty serious for these tiny engines, i'm planning on doing the flow mods including cams and only dream of getting similar gains.
Old 02-14-2016, 09:59 PM   #7
rabbito
rabbito's Avatar
JUN Cams? my dream.....my cousin have Vios(yaris sedan) with Jun Cams, full exhaust, E85 ecu tuned...car just jumps..
downside is i feel engine is idling loud or is it ticking? and very expensive.......
i got headers and center pipe done first before any other mod..yes, you do notice the gain
Old 02-14-2016, 11:36 PM   #8
1nz revolution
Drives: 1nzfe
I run custom JUN 10.5 race cams with Ferrea valves and springs. Beautiful set up.
1nz revolution is offline   Reply With Quote
Old 02-10-2016, 08:13 PM   #9
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
How far did you advance the timing? You will definitely need to take it to a Dyno to confirm numbers. Saying that you think 30-40whp via butt Dyno is just plucking numbers out of the air.
Sent from m-o-b-i-l-e
Old 02-12-2016, 10:06 PM   #10
rabbito
rabbito's Avatar
i didnt say whp(whose going to gain 30-40whp without internals...i mean seriously, thats like 60bhp..lol), 30hp came from a friend of mine who had chiptuned same ecu and same tuner without any modification on dyno, i used the exact same set up and put inside my car. i guessed 10 from all the modification that i did without ecu
Old 02-12-2016, 10:31 PM   #11
rabbito
rabbito's Avatar
"future modification" listed above with E85 setup is completed..
- aftermarket performance oem replacement shock & spring
- mu spec brake pads
- hankook v2 tires but im regretting like crazy, should have got the hankook RS3s....
Can the Yaris run on E85? Anybody try it? auxmike DIY / Maintenance / Service 37 04-06-2019 07:52 PM
E85 All Motor Build rabbito Performance Modifications 25 02-07-2016 11:01 AM
e85 kits chancellor6869 Performance Modifications 6 01-22-2015 09:36 AM
DAMN! Just put E85 in my car by accident... TheCutsman Fuel Economy Forum 9 08-12-2009 10:51 PM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
