Old 12-07-2015, 02:54 AM   #1
rabbito
rabbito's Avatar
E85 All Motor Build
I just started this project a month ago..2012 1NZ 1.5 Toyota Vios (Yaris Sedan) from Thailand..Im trying to do cheapest way possible..Jun bolt on camshaft is really way to go but Im not going to purchase this due to finance issue..lol
- Simota intake (i took them off and changed them back to K&N drop in cause i lost low end power and sounds hella retarded..)
- Yaris RS Japan (Vitz RS) C coded MAF sensor, RS VVTI oil valve , IX spark plugs (stock E coded 1nz vvti opens around 4000rpm, C coded maf with rs vvti opens valve around 2500rpm)
- Header
- Front strut, rear sway bar
- Battery volt balancer
<upcoming parts>
just ordered custom mid pipe to fit with the header..(stock yaris header and mid pipe has too much restriction)
still looking for 1zz throttle body (i will probably add hks intake)
found the pulley but still thinking about it..im not sure if this is worth the upgrade
kyb shocks with tanabe springs (coming soon)
hankook tires (my tires are slipping..i need some good tires)
just ordered 1jz injectors(280cc) to replace my stock 1nz injectors(200cc)..this is for E85 flex fuel over boost +30% when i chiptune the engine..
E85 flex fuel kit
E85 chiptuning + dyno
I will update everyone with further modification
Can the Yaris run on E85? Anybody try it? auxmike DIY / Maintenance / Service 37 04-06-2019 07:52 PM
e85 kits chancellor6869 Performance Modifications 6 01-22-2015 09:36 AM
DAMN! Just put E85 in my car by accident... TheCutsman Fuel Economy Forum 9 08-12-2009 10:51 PM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
