#19 | |
feed my pet
Yeah Okada are costly but there are other options. T.M. Works specialize in ignition tuning products. I'm using their basic harness: http://tmworks-web.jp/products/dph_eng.htm or you can go further with 16v: http://tmworks-web.jp/products/alpha_eng.htm and even a few more stages of upgrades. Their full stage upgrades might be even more costly vs Okada and the debate is still going on which is better. |
#20 |
Mr. 155 and climbing
The Okada doesn't really net much for the investment really. On a ka20 for example with a GT2835 @ 8PSI only gains 7whp and 17tq. Of course as the boost increases you will see a larger gain but it isn't exponentially linked.
I am very intrigued by the idea of using the higher end Vitz coil packs. Wish that there was a spec sheet comparison between them and the standard coil packs. I am sure when we Dyno my newest setup we will see if it would be of any benefit to make the upgrade. Sent from my XT1575 using Tapatalk
#21 | |
feed my pet
#22 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
http://www.amazon.com/gp/product/B00...rcuprojeele-20 It would all be a matter of finding an apropriate size that would deal with the heat that gets generated from the constant operation. As a bonus, it's adjustable, so you can crank up the voltage even more if you're feeling brave.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#23 | |
feed my pet
#24 |
![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
racecars run 16 volt batteries a lot in the us.no danger I think of burning up your plugs ha ha.
#25 |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
my E85 build is completed..you can check the "E85 Motor Build II" post from perfprmance modification section..
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#26 |
![]() ![]() Drives: 1nzfe Join Date: Jan 2016
Okoda direct spark coil pack. Direct-port nitrous.
| Can the Yaris run on E85? Anybody try it? | auxmike | DIY / Maintenance / Service | 37 | 04-06-2019 07:52 PM |
| e85 kits | chancellor6869 | Performance Modifications | 6 | 01-22-2015 09:36 AM |
| DAMN! Just put E85 in my car by accident... | TheCutsman | Fuel Economy Forum | 9 | 08-12-2009 10:51 PM |
| Consumer Reports on Ethanol | Driver | General Yaris / Vitz Discussion | 6 | 09-01-2006 11:21 AM |
