![]() ![]() Drives: Vitz S 2007 LB Join Date: Feb 2013
My Dyno Run
guys, this is my cars dyno run... the car came as an 1.5s 1nz-fe, auto, full stock, for some reason it was equipped with a 2nz-fe intake manifold, dont ask why, i got this car used from a car dealer.
my 1st original run, 1zz-fe throttle body, 4-2-1 header, stock mid and blitz nur-spec S-Flow Exhaust, nothing else. ![]() 2nd run, after a lot of 4-2-1 and 4-1 debates, switched back to the 1nz-fe throttle body, after that i bought a 4-1 header, 0.2mm thick, mandrel-bent full stainless steel piping with a huge S-Flow midbox, wouldn't say its fully S-Flow, it just enters from the top in the inlet, appears middle in the outlet, both 2 inches wide, full stainless again to the rear, then the blitz nur-spec S-Flow Exhaust ![]() 3rd run, after that was done, i did a lot of research regarding the differences of 1nz-fe intake manifold and the 2nz-fe intake manifold, got the same responses, they are the same, not satisfied,i got myself the 1nz-fe intake manifold, plugged it in with the 1nz-fe throttle body, got myself this, a headspinner. ![]() CRAZY, 14whp! 4th run, this time i did the 1nz-fe to the 1zz-fe throttlebody transplant, but noticing the difference between 46mm and 55mm, i decided to create a spacer that would downsize the hole, to create a better airflow, and i got this ![]() bear in mind that all these are done without the engine management control.. more to come...... |
sorry guys, i did not resize it for better viewing, haha..
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
I'm amazed great numbers... The difference has to be really noticeable when you floor it
R-CaT Project Yar 2ZR |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
At first i was like...wtf...but then i read.
Nice work...still a little low...i dunno if thats gas or automatic or what but your close to where it should be For reference mine was 107/104 with just a full exhaust...now its 105/104 (with more midrange torque) with a Tooter spacer and a short ram (power was even less with the stock airbox and the Tooter...like 103/103). My part throttle torque still amazes me
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Ragnacat: its quite noticeable...
malibuguy: yes, its quite low, its gas, automatic and i am still not impressed yet. i do get that my car is a bit shy when it comes to full throttle, it sort of going up the steps, lots of torque, then it slows, then repeats, not so much of noticeable, but its there, i can feel it, anyone experienced this kind of symptoms before? |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
so the 2nz intake manifold realy is crap huh?
Thanks for the post
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
Its not crap, but 1nz-fe intake manifold is a recommended upgrade, based on the dyno charts..
![]() ![]() Drives: 09 Yaris Hatchback Join Date: Oct 2014
if you don't mind me asking, How much did it cost to dyno your car? I would like to get my car dynoed before going turbo.
Obsessed with 1.5L
I meant more about the quality of the gas
its RM60 in malaysia, so roughly, 18 bucks in america
quality of the gas is ron 95 here in malaysia
![]() Drives: Ncp42 Join Date: Jan 2016
Woah another brother from malaysia!
| Mighty yaris dyno run! >:D | Black_griffin6 | Photo-Video-Media Gallery | 0 | 01-02-2014 12:04 PM |
| Dyno results | PETERPOOP | Forced Induction Forum | 28 | 12-09-2009 12:01 PM |
| dyno day | psychopinay42 | California | 1 | 08-03-2009 04:42 AM |
| Dyno and Videos | ruimond | Photo-Video-Media Gallery | 23 | 02-01-2009 08:34 AM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 11:14 AM |
