Old 11-11-2009, 05:15 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Dyno results
Well I went to the dyno today. The last time I went to the dyno, I managed to get 133whp. However, that was on my first and only pull. The reason I only did one pull was because I was running too lean to continue with anymore pulls. After that I got 1zz injectors, and my lean problem is non existent. I only now finally made it to the dyno again, and got to do three pulls.
This is my "before" dyno. The reason I say that is, because I had NST make me a custom overdrive crank pulley, with a smaller water pump pulley. This will hopefully give me a couple more lbs of boost. I will be going to the dyno again this Saturday to get my "after" dyno results done. For now, here are my results from today...
Mods: blitz s/c, aFe intake, Megan Header, 2.25" headerback exhaust, 1zz injectors.
Probably could make a few more whp if I had the 1zz throttle body and water/meth injection. However, I don't have plans on using those two. Just the overdrive crank pulley which will be installed and dyno'd this saturday, and then eventually tune everything up with the greddy emanage ultimate.
1st pull in 3rd gear: 136 whp 135tq
2nd pull in 4th gear: 135whp 133tq
3rd pull in 3rd gear: 140whp 135tq
I am positive about the whp numbers, just can't quite remember the torque numbers. I know they only varied from 133-135whp.
I don't have the dyno sheet. The printer was out of ink, and I will get it on Saturday when I dyno with the new pulleys.
Here are the pulleys that I will be installing for the dyno on Saturday.
Originally Posted by NonStopTuning View Post
The first ever CUSTOM NST Overdrive Crank Kit for the Blitz SC Toyota Yaris
Old 11-11-2009, 05:34 PM   #2
that just plain ROCKS. very nice.
how much boost did you see at peak?
what was the A/F at peak?
can't wait for Saturday...
Old 11-11-2009, 06:34 PM   #3
H3LlIoN
Drives: '09 Yarrrr hatch
Mods: aFe intake, Megan Header, 2.25" headerback exhaust, 1zz injectors.
I can just see somebody rolling in here and being like "Holy sh%t, you picked up 33hp with intake and exhaust!!!
What did the pulleys cost? One thing too I never knew, is the stock rating of 106 at the wheels or crank? I'm assuming your 140 is to the wheels...
H3LlIoN is offline   Reply With Quote
Old 11-11-2009, 06:42 PM   #4
Morgan
Morgan's Avatar
Drives: 07 MM LB
wait.... when did nst make an overdrive pulley?
Old 11-11-2009, 08:14 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I think PETERPOOP forgot to add one more important mod to that list. :)
Old 11-11-2009, 08:20 PM   #6
PETERPOOP
PETERPOOP's Avatar
woops. blitz s/c ;)
h3lion: I wrote "whp." So yah, to the wheels. Stock is about 85 whp. Toyota advertises 106 to the crank.
Morgan: I've been in talks with them for months about it. ;)
Garm: My AFR on the dynojet was 12-12.5 I believe. However my wideband reads 10.5. They were saying it must be the hi flow cat that is making it read higher ( since they read the AFR from the exhaust tip ). My max boost was 8 lbs of boost.
Old 11-11-2009, 09:40 PM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
All that power and no where to go. What's happening with Barbers Point?
Old 11-11-2009, 10:35 PM   #8
1NZYaris1
1NZYaris1's Avatar
nicely done peter .
i will be waiting and watching like everyone else .
All the best for Saturday , you might just make it to half of Garms 310. sorry just stirring
Old 11-11-2009, 11:24 PM   #9
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Wow! That's a mighty-fine set of pulleys. Glad to see someone really doing things "right", and using a quality-first approach. I think you've got a damn solid setup there. I'm excited to see the updated dyno. BTW - what brand of dyno?
Old 11-12-2009, 01:25 AM   #10
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
dynapack
Old 11-12-2009, 01:57 AM   #11
PETERPOOP
PETERPOOP's Avatar
wrong. dynojet @ radmotorsports. ;)
Old 11-12-2009, 02:40 AM   #12
H3LlIoN
Originally Posted by H3LlIoN View Post
What did the pulley cost?
Old 11-12-2009, 09:43 AM   #13
PETERPOOP
PETERPOOP's Avatar
Since the pulleys are not on the market yet, I don't think I should say. Not sure what NST will be trying to sell them for, if successful.
Old 11-12-2009, 10:22 AM   #14
hard to say what they'll charge...
Old 11-12-2009, 11:29 AM   #15
ok, let's clear up a couple of things, besides huge PROPS and CONGRATS to peterpoop!
140 whp @ 8 psi is really good for that little blower.
@ thebarber: The overdrive pulleys are for a very small limited market, so they will be a short run and I will bet a paycheck (what's that?) at least a little more expensive.
If NST makes a run, I'll be selling them AND pre-packaged with supercharger kits.
<-- I think 90-95 is what has been reported most frequently.
Old 11-12-2009, 12:23 PM   #16
was just throwing out an idea....perhaps i shouldnt have...
Old 11-12-2009, 04:22 PM   #17
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
You went to RAD - I see.
They better have ink for the printer by Sat.
Old 11-12-2009, 09:01 PM   #18
PETERPOOP
PETERPOOP's Avatar
was it 95whp garm? Yah, i don't think I've ever seen a stock dyno.
My DynaPack Dyno Results. PETERPOOP Performance Modifications 63 03-10-2009 06:02 AM
TS/Xd Long Tube Header & Intake dyno results richardholdener Yaris TS Talk 21 01-06-2009 05:28 AM
NST Pulley Dyno Results richardholdener Performance Modifications 51 12-18-2008 09:11 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
