Old 10-05-2016, 12:44 PM   #1
dogsridewith
Drives: 2007 2-door hatchback
Loose air-blocking panel at right side of radiator--rattle, squeak, buzz?
(Loose air-blocking panel at right side of radiator--rattle, squeak, buzz?)
Moves freely vertically an eighth or quarter of an inch. Larger than the panel on the left side of radiator, which seems tight.
Will put a piece of foam under it to take up play, pending suggestions. Curious if this involves broken or missing clips or trim, etc. (Mine had a right headlight replacement, so maybe something got altered.) Definitely something to check on any Yaris as a potential noisemaker.
Old 10-05-2016, 07:34 PM   #2
That is a large plastic piece, which should not have been touched when the headlight was replaced, but you never know. It just snaps into place.
DIY rear Interior panel removal 09 3dr LB bkndacn Cosmetic Modifications (Exterior/Interior) 10 03-11-2013 01:05 AM
driver side A/C vent blowing hot air Yaross DIY / Maintenance / Service 4 12-05-2011 07:51 AM
Side impact air bags... do I have them? chumpster Cosmetic Modifications (Exterior/Interior) 6 04-27-2009 07:04 AM
