Old 11-04-2016, 11:54 AM   #1
bronsin
bronsin's Avatar
ABS Light On
It's on my wife's 05 Camry but the people on the forum there are dufusus.
Unlike here.
What could be wrong. Where should I start looking?
Can that trigger a code. The CEL isnt on.
I recently had the car up on a lift with the wheels and brake drums off. Everything looked like new.
Thanks!
Old 11-04-2016, 12:02 PM   #2
tmontague
tmontague's Avatar
Does the and still work?
I'd start by pulling the sensors and connectors and cleaning and adding electrical grease
Old 11-04-2016, 12:23 PM   #3
bronsin
bronsin's Avatar
The and?
Old 11-04-2016, 01:04 PM   #4
ABS Light On
and = abs
ABS faults will not trigger a CEL.
Prob an issue with one or more sensors on the hubs.
Old 11-04-2016, 06:49 PM   #5
bronsin
bronsin's Avatar
Wife says abs light went out on trip home.
Learned lots about what to check if it comes back on.
Old 11-07-2016, 10:14 PM   #6
bikeshox
Drives: 07' Sedan
For future reference, I agree with pulling the connectors, cleaning and greasing. It fixed my problem 100,000 miles ago. Never had the problem since.
bikeshox is offline   Reply With Quote
Old 11-08-2016, 12:38 AM   #7
SirDigby
Drives: 2007 yaris 3 door
some yaris have issues with the rear sensors. they are built into the hubs and can't be removed. the hub has to be replaced. I had this issue last winter when it gets cold out. I cleared the codes and it hasn't come back. (also has not got cold enough yet)
did you pull the codes? it will give you a much better direction of where to find the issue instead of blindly cleaning parts and hoping for the best. any parts shop will pull the codes for you. (most will not clear the codes, they want you to buy parts...)
Old 11-08-2016, 01:46 PM   #8
chief ten bears
chief ten bears's Avatar
My 2007 had an abs light once, it was triggered by a rear sensor. I removed both rear plugs, cleaned the connections with contact cleaner, applied some dielectric grease and reconnected them and the code and light automatically cleared.
The rear sensor plugs accumulate moisture and dirt, especially on winter climate cars.
Sent from my Blackberry Priv using Tapatalk
chief ten bears is offline   Reply With Quote
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 04:03 PM
Noise From ABS when Braking + ABS & (!) Light On - Please Help Chris Jackson DIY / Maintenance / Service 2 04-23-2016 01:00 AM
yaris abs brake light speedometer and electric powersteering issues dave van muyden DIY / Maintenance / Service 4 10-26-2013 03:33 PM
Resetting abs light on 58 plate yards jackg205 DIY / Maintenance / Service 1 06-24-2013 07:43 AM
HELP / Spoiler connecting light SimTronik DIY / Maintenance / Service 4 11-03-2010 12:08 AM
