Old 06-24-2013, 05:08 AM   #1
jackg205
Drives: yaris
Resetting abs light on 58 plate yards
I have changed a rear wheel bearing on a 58 plate yaris and after doing so the abs light is on I have tried to reset following probing pins on the obd pin and following the procedure to reset but it hasn't worked does anyone know how to clear the abs light without taking it to a garage to be reset?
jackg205 is offline   Reply With Quote
Old 06-24-2013, 07:43 AM   #2
When you did the jumping of the pins on the OBD port, were you able to see the ABS light flash to indicate the DTC?
If so, and the error indicates the sensor on the wheel where you changed the bearing, you may have damaged the sensor in the process of changing it, and that is why you can't clear the DTC.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 11:06 AM
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 03:59 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 04:09 AM
