![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
5 lug conversion on a 2014 Yaris?
Is there a way to convert to 5 lug hubs? I heard somewhere a while ago that you can take hub assemblies from a 2nd gen Prius that they plug and play?
Has anyone ever looked into this? Thanks! Sent from my iPhone using Tapatalk |
Pretty sure you need xD parts.
2ZR swap. DO IT! Ask how!
Or some really awful wheel spacer adapters, but then you would have to run about 20mm shorter offset.
*Edit* Some Spec Miata wheels are ET20. Stock Miata wheels are about the same as ours, 38-45. You'd have to make sure you knew exactly what you were buying to not have problems. The alternative would indeed be to do an xD swap, but there are still some unknowns up front with the axles. Someone on the forums recently put an xD trans in a Gen2 Yaris and had a hell of a time getting the right shafts to mate from the xD differential to the Yaris hubs. |
#4 | |
#5 | |
I dont remember exactly what diameter pattern the 5 lug wheels were that I was looking at, I'll go back and look. There were usually 16 inch and 17 inch wheels by 6 or 7 wide
#7 | |
https://www.tirerack.com/wheels/resu...9&autoModClar=
seems like a giant waste of time and money
Radical Dreamer
Drives: spiritedly. Join Date: May 2016
Agreed.
Enjoy Family Car Sports |
Also, I'm not into wheel spacer adapters. That's asking for trouble. I have regular wheel spacers in the same lug pattern (not adapters, per se) in 20mm front and 30mm rear but thats as far as I'll go with spacers. Adapters are trouble. Thanks guys!
Radical Dreamer
What wheel style were you looking at?
4x100 ruled by 90s civics, miatas, e30/2002 bmws and toyota front wheel drive cars. Only thing i hate is the offset is usually found +30 or less...or 8 inches wide.
| 2014 yaris bought at hertz | jstert | Third Gen Yaris General Discussion | 9 | 05-21-2016 07:13 PM |
| 2014 Yaris LE Fog lights installation help. | Eforno | DIY / Maintenance / Service | 0 | 01-05-2016 07:20 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 12:03 PM |
