Old 03-31-2017, 08:28 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Or some really awful wheel spacer adapters, but then you would have to run about 20mm shorter offset.
*Edit*
Some Spec Miata wheels are ET20. Stock Miata wheels are about the same as ours, 38-45. You'd have to make sure you knew exactly what you were buying to not have problems. The alternative would indeed be to do an xD swap, but there are still some unknowns up front with the axles. Someone on the forums recently put an xD trans in a Gen2 Yaris and had a hell of a time getting the right shafts to mate from the xD differential to the Yaris hubs.
2014 yaris bought at hertz jstert Third Gen Yaris General Discussion 9 05-21-2016 06:13 PM
2014 Yaris LE Fog lights installation help. Eforno DIY / Maintenance / Service 0 01-05-2016 06:20 PM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
