Old 03-04-2017, 08:55 PM   #1
ysar
Drives: 2007 Yaris
B-Spec build Norcal #86
I just turned 50 and my big plan for the milestone was to do a lot of SCCA racing culminating in a trip to the Runoffs at Indy. Well, my knee had something to say about that, and now I'm going to miss a big chunk of the season due to surgery and recovery. Enough about me, let me describe the car.
To begin, I wanted to build a car that was street, race, and rally legal. I also didn't want to spend a lot of money. I considered modifying my Lemons/Chump/LuckyDog Miata, but making it street and rally legal would be expensive. So I decided on B-Spec, and specifically the Yaris because it has the least expensive kit and has been around nearly 10 years.
I purchased the 2007 Yaris for $3040 from a woman who was driving it cross-country from North Carolina to California. I had a racer friend on the other side check it out for me. After taking delivery, I used it as a daily driver for about 6 months, during which time I took it to a few track events where I was doing some coaching. I found it to be a great commuter, getting over 40 mpg, and a surprisingly fun track car even in stock form. I even took it to a rally school (Primitive Rally) where it was one of the faster cars on the course. I really liked the car and part of me really didn't want to do the full B-Spec conversion...
The cage was constructed at a cage-welding class held by master cage-builder Jon Pagel of Evil Genius Racing. He oversaw the operation and did a little welding, but most of it was done by students. In the end, I got the cage built for about 60% of the usual cost. It doesn't yet have the A-pillar vertical bars, so it's not yet fully rally legal, but the rest of the cage meets rally specs. It's probably going to be at least a year before I do stage rally anyway, and in the mean time I can do RallyCross and RallyTrials along with road racing.
The performance mods for a Yaris B-Spec are: (1) suspension (2) exhaust (3) intake (4) tires (5) brake pads. The suspension is a TRD kit that costs about $650. The exhaust is just a 1 minute job with an angle grinder. The intake is optional, and I really don't know if a K&N filter improves much over a paper filter. In any case, all together, I got 101 HP and 105 TQ. It's more than I expected. Wheels and tires are SM-ish: 15x7, 205/15/15, 13+ lb rims, DOT slicks. I've got a set of Toyo RRs, Hoosier SM7s, and RE-71Rs. For rally, I've got steelies and Cooper Weathermasters up front and runflats out back. I'm using EBC Green Stuff for the front pads and something OEM-ish in the rear.
Safety stuff is the usual: seats, harnesses, fire system, kill switch, window net, center net, tow hooks, and various stickers. Other stuff include wide-angle mirror, quick-release steering wheel, fuel sample port, tachometer, extra fire bottle, extra electrical outlets, bluetooth radio, rally lights, and AiM SoloDL. A cool thing about the SoloDL is that it talks CAN bus to the Yaris ECU. It can be quite expensive to set a car up with telemetry, but all cars since 2008 (and sometimes before, like the 2007 Yaris) have loads of sensors and a high speed network built in. The Yaris reports RPM, vehicle speed, individual wheel speeds, steering angle, brake, clutch, throttle, and all sorts of engine stuff. It would cost thousands to put all this stuff in an older car.
ysar is offline   Reply With Quote
Old 03-04-2017, 10:18 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Welcome! Hope you get lots of events in.
Old 03-05-2017, 03:09 AM   #3
Nice.
You're not too far from me. So I'm assuming you just cut the exhaust off????
Also, I don't think you'll be driving that car on the streets anymore, so why not pull out anything associated with the audio system and do some weight savings?
Old 03-05-2017, 11:02 AM   #4
ysar
Drives: 2007 Yaris
Nice.
I cut the exhaust off right before the can. I also have a stock exhaust for around town. I have a radio and other comforts so that I can drive to the track. I don't like towing and would argue that it's safer driving this car than my tow rig. The bars are well padded and a long way from my head. The B-Spec weight is 2425 lbs with driver. I actually have to add weight at this point. I'm hoping the cold box will be enough, but if not, I can put a spare tire in as ballast.
Old 03-06-2017, 02:03 AM   #5
Cold box? What's that?
Didn't realize you still drive the car on the road (didn't think it would be legal due to the roll cage). How much more weight do you have to add to be class legal? Aren't you still adding more to the cage, so that should add some weight. Does the TRD kit you got have the rear sway bar? If not, that should add a few lbs. And good idea about balancing out the weight distribution by the spare tire.
I have no knowledge on track/auto-x racing, btw, so I have no clue what parts are legal and not legal in classes.
Old 03-06-2017, 01:45 PM   #6
Jason@SportsCar
http://coolshirt.com/motorsports/
Old 03-06-2017, 02:03 PM   #7
ysar
Drives: 2007 Yaris
Originally Posted by Jason@SportsCar View Post
Coolshirt and FAST are the standards, but I don't actually run their products in my cars. For the Miata, I built the cold box from a large ice cooler and a bilge pump. I needed the capacity to run in 100° weather for 2.5 hours. The Yaris is built for sprint racing, so the cold box can be much smaller. Rather than buy one for racing, I got a cold therapy unit on ebay for about $50. There are lots of brands of choices out there. McMaster-Carr sells fittings if you want to build or modify.
Old 03-06-2017, 01:54 PM   #8
ysar
Drives: 2007 Yaris
I'm only 35 lbs under weight. Fuel and tire should do it.
I'm not running the rear ARB because it's not part of the kit.
Old 03-05-2017, 10:18 AM   #9
Dabuu
Radical Dreamer
Drives: spiritedly.
Awesome!! Can't wait to see videos. :)
I wanted to do a B-spec build with mine, but since it's my daily, I'm loosely following the rules, I call it my Wanna-B spec build. lol
Enjoy Family Car Sports
Dabuu is offline   Reply With Quote
Old 03-05-2017, 11:47 AM   #10
ysar
Drives: 2007 Yaris
Here's some video before the build was complete.
https://youtu.be/HJC_P5FpByU
Old 03-06-2017, 02:05 AM   #11
Have you replaced the brake lines with SS lines and the brake fluid with something more race oriented like Torque RT700?
Old 03-06-2017, 01:57 PM   #12
ysar
Drives: 2007 Yaris
I don't run SS lines in either of my racecars. I do run a high temp brake fluid, but I'm not that picky about brand. There isn't all that much braking in a B-Spec.
Old 03-07-2017, 03:37 AM   #13
Always wondered how racers stayed cool in those HOT cabins during a race. Thanks for the info on what it is.
So I'm assuming in that class, the rear sway bar would be illegal since it didn't come in the TRD package???
Ah, didn't know not much braking is involved in that class.
Old 03-07-2017, 01:11 PM   #14
ysar
Drives: 2007 Yaris
So I'm assuming in that class, the rear sway bar would be illegal since it didn't come in the TRD package???.
Each B-Spec build has specific components and the ARB isn't one of those. That's the simple answer. How one designs a kit and then modifies it probably involves discussions with the SCCA. Hopefully Jason will enlighten us...
Old 03-07-2017, 02:23 PM   #15
Jason@SportsCar
Toyota had no official interest in supporting B-Spec when the class first came on line - still don't - it gets the same level of support as an other Club Racing class.
Because we were already working with Yaris marketing team we were asked to work with SCCA on the B-Spec program. But with no support, or interest from TMS, there was little to do. Originally the car was going to run in BS nearly stock. We suggested tossing in the already available TRD springs and shocks just to try and lower the car a little, making it less prone to a roll. We did not ask for the rear bar because adding a torsion bar to a stick axle is kind of pointless. You can call it a swaybar if you want, its not, and does not function as such, just cost money and adds weight.
If you take a look at most of the other BS kits they are all adopting the Mazda/CorkSport "rear bar", which is also not a swaybar, its tube with tie rod ends they use to bend the axle to adjust toe. You can accomplish the same thing with shims on the rear axle.
Recently a new BS committee was formed, the previous one was made up of manufacturer reps, the new one is racers. The new committee wants to speed the class up, so they started opening up the restrictor plates on the fast cars (Honda, Kia, Mini, Chevy), and giving things like a CAI to the slower cars. The Mazda2 also got a header. All of these changes are just leaving the Yaris further behind due to the lack of an ECU reflash - and they wont allow a piggyback.
At the 2011 Runoffs they invited all of the manufacturers that had built BS cars to bring them for a demo race. We shipped out one of the cars we had used for a Sony Play Station program (built to BS trim), we were very disappointed to find out the "demo race" was five laps behind a pace car. We spent the money to ship the car and expected it to race, so we started looking at other options... Since BS was not yet a class, we could only field the car in H Prod or Showroom Stock C. We found an SSC driver that had engine problems in qual, and let him run the Yaris - giving us the first BS car to compete at the Runoffs.
Old 03-06-2017, 12:03 PM   #16
Dabuu
Radical Dreamer
Drives: spiritedly.
I wish Toyota offered a better B-spec package like Mazda and Honda. :(
Old 03-06-2017, 01:43 PM   #17
Jason@SportsCar
Just a heads up, in the March Fastrack there are a number of rules/spec changes for B Spec. You can now run -3 front camber, previous limit was -2.5.
The Yaris also picked up the K&N intake (full system, not just a drop in filter), and a new suspension package including Bilstein struts and any spring up to 500lbs.
Cold air intake K&N 69-8612TFK is allowed.
Allow Bilstein kit 47-237834
Still not going to be competitive with the other makes, since the Yaris is effectively the only one stuck on a stock ECU tune.
Old 03-06-2017, 01:52 PM   #18
ysar
Drives: 2007 Yaris
The max camber I could get was -2.5. The K&N intake isn't CARB legal, so I can't (honestly) use it in California. So basically my non-competitive B-Spec just got a little less competitive.
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 05:21 PM
SCCA Houston Region B Spec build :) FHT_Racing Tracking, Racing, Auto-X Forum 126 11-11-2014 02:08 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 11:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-16-2013 12:44 AM
12/20/08 Buddy Club USA 5th Anniversary Clearance SALE DuckinOut California 3 12-18-2008 01:25 AM
