Old 03-05-2017, 10:02 AM   #4
ysar
Drives: 2007 Yaris
Nice.
You're not too far from me. So I'm assuming you just cut the exhaust off????
Also, I don't think you'll be driving that car on the streets anymore, so why not pull out anything associated with the audio system and do some weight savings?
I cut the exhaust off right before the can. I also have a stock exhaust for around town. I have a radio and other comforts so that I can drive to the track. I don't like towing and would argue that it's safer driving this car than my tow rig. The bars are well padded and a long way from my head. The B-Spec weight is 2425 lbs with driver. I actually have to add weight at this point. I'm hoping the cold box will be enough, but if not, I can put a spare tire in as ballast.
ysar is offline   Reply With Quote
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
SCCA Houston Region B Spec build :) FHT_Racing Tracking, Racing, Auto-X Forum 126 11-11-2014 01:08 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
