Old 03-06-2017, 12:52 PM   #18
ysar
Drives: 2007 Yaris
Originally Posted by Jason@SportsCar View Post
Just a heads up, in the March Fastrack there are a number of rules/spec changes for B Spec. You can now run -3 front camber, previous limit was -2.5.
The Yaris also picked up the K&N intake (full system, not just a drop in filter), and a new suspension package including Bilstein struts and any spring up to 500lbs.
Cold air intake K&N 69-8612TFK is allowed.
Allow Bilstein kit 47-237834
Still not going to be competitive with the other makes, since the Yaris is effectively the only one stuck on a stock ECU tune.
The max camber I could get was -2.5. The K&N intake isn't CARB legal, so I can't (honestly) use it in California. So basically my non-competitive B-Spec just got a little less competitive.
ysar is offline   Reply With Quote
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 04:21 PM
SCCA Houston Region B Spec build :) FHT_Racing Tracking, Racing, Auto-X Forum 126 11-11-2014 01:08 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
