![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
Whiteline Bushing Install Questions
Good day/evening/night everyone,
I just purchased the Whiteline W53303 and I notice the hole for the bolt is off center which I assume allows for the caster correction. Questions: 1) Does the off center hole face the front or rear of the car? 2) Are the washer/spacer installed as in the pic or inversed? I have attached a photo of the bushings Thanking everyone in advance |
I think I just figured it out
![]() If the offset hole is to the rear of the car it pushes the bottom of the cradle forward resulting in positive caster and if the offset hole is to the front of the car it pulls the cradle back and results in negative caster. When installed and being professionally aligned the technician will adjust the caster accordingly. Although the work will be done by professionals I always like to know what they are doing or have to do so I can have peace of mind. Do correct me where necessary. |
#3 | |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
ToyotaBuzz has installed these, maybe PM him he is super helpful
Yes I agree the installation guide isn't helpful. I will take pictures n post as I planning to do this Tuesday.
I will try and PM ToyotaBuzz but I don't want to be harassing anyone will he be ok with a random PM Klick |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I put mine diagonally from the ballpoint like the voids in the bushing
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
^^^ wouldn't putting them diagonal also affect the camber?
Actually, if you draw a triangle as in the shape of the control arm, the bushings need to either face the inside of the car or outside of the car to adjust for caster. Because what you're actually doing is pulling the rear of the controller in towards the center of the car or pushing it out.
^^ now u have me confused lol
Klick |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
The idea is to push the back end of the lower control arm towards the outside of the car, this rotates the entire arm forward, giving you additional caster.
Looking from above: depending on if the hole is towards the center of the car, or the outside, determines the location of the ball joint because it twists the entire arm. Push the ball joint forward gains caster, pull it back and you lose caster.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
Exactly |
That makes a lot of sense. The cradle pivots at the front bushing and rotates accordingly. Well at lest I was on the right track
![]() Thanks everyone for assisting. Ill do my best to provide some pics. |
Is this suppose to fit a vitz RS. Doesn't seems so to me. There is a ridge under the bushing that doesn't allow the washer to move toward the centre of the car. This prevents the top n bottom washer from lining up with the bushing centre. Any help will be appreciated.
Klick |
#14 |
What chassis code is it supposed to be for? NCP##
Sent from my iPod Touch |
#15 |
Ncp91 as far as I know. Also when the top washer fits into the groove of the chassis it is off center so the bolt cannot go thru it.
Klick |
#16 |
I don't know what to do at this point seems like a waste of bout $250usd as I doubt it can't work or be returned at this time.
Klick |
#17 |
Well gonna put in d old bushings tomorrow...such a waste
Klick |
#18 |
Vehicle 2007 Vitz RS NCP91
Pic 1 shows W53301 fits good and correct no problem Pic 2 shows W53303 this is the bushing I am having difficulty fitting Pic 3 and 4 shows where the washer provided need to fit however when the washers are fitted they didn't line up thus the bolt doesn't go thru them. If I need this to work I need to Make the washer holes larger/oval and cut off the tabs that hold the washers. Is this advisable? |
| FS NorCal: Yaris/Prius C Partout: KW V3 / Whiteline / Greddy Ti-C / Etc | B2FiNiTY | Items for Sale by private party | 25 | 04-25-2014 01:47 AM |
| Whiteline Polyurethane Bushing Review | Monstro | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-15-2013 11:24 AM |
| alternator bushing JAMMED ! | Siffleu | DIY / Maintenance / Service | 12 | 10-22-2010 10:12 AM |
| Gauging Interest: Whiteline Front/Back Adjustable Sway Bars | RaptorRacing | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 12-15-2009 04:23 AM |
| NEW NST SS Shifter Bushing (AE86) | NonStopTuning | NonStopTuning | 3 | 10-01-2007 03:12 PM |
