#1 |
![]() Drives: 2010 Black Yaris Lb Join Date: Apr 2010
Whiteline Polyurethane Bushing Review
Hey guys, just wanted to tell everyone about a great upgrade for handling!
I installed Whiteline synthetic elastomer control arm bushings and I have to say wow! The car feels much more planted through turns, especially mid-corner. It also seems it reduced a good amount of under-steer during initial throttle application, I am not sure if that is because of a reduction in front end compliance though. Be aware that you will have issues installing these if you have a sub-frame brace, due to these bushings being much less compliant; also always perform an alignment after any suspension work. Bumps are a little more noticeable, but not bad. All in all a very good modification. Supporting mods. TRD suspension kit TRD rear sway bar GTSPEC front, mid, rear chassis bracing Ultra racing front strut brace Team dynamics 15x6.5" et +38mm Monza R wheels 195/55/15 Hankook Ventus v2 tires |
Great product, and in stock.
#3 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
How do you like your tires I am looking to buy the same ones and size in a few weeks. I been looking to do these bushings I notice my caster is off last time I did my alignment so if I'm going to replace worn put using might as well upgrade them at the same time
#4 |
I do have Whiteline control arm bushings ... and my only problem is when I drop in a pothole and bump (you get to believe by the sound that you damaged your car (with the time you get use to it). Beside that they are wonderful.
#5 |
LOl probally one of the main reasons oem is rubber.
| bushing came off metal sleeve on rearstrut? tein coilover | TRD.RiC | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 03-18-2012 11:14 PM |
| alternator bushing JAMMED ! | Siffleu | DIY / Maintenance / Service | 12 | 10-22-2010 11:12 AM |
| Polyurethane? Bushing Kits? | bronzebullet232 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 06-18-2010 04:45 PM |
| Review of the 2009 5-door and 3-door Yaris Liftbacks | csburdick | General Yaris / Vitz Discussion | 14 | 01-03-2009 08:09 PM |
