![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2016
2 keys to unlock doors/hatch/ignition (only want one key)
Hello,
Struggled with a title for this, so I'll try to do better in the body. I have a 2006 Yaris 2 door lift (hatchback). I bought it used about a year ago. It has 2 x different keys. One operated the hatch and the other works the 2 x doors and the ignition. I ASSUME (hopefully) that it only had one key from the factory. In which case I'd like to get back to that setup. I stopped by a locksmith today and asked them what it would cost. He said STARTING $250! That seems a tad pricey. It there an easier/cheaper way to do this? I just want all the locks/ignition on one key. Thanks in advance, Russ |
So you want the lock barrel in the hatch to match the barrels in the doors and ignition. I have no idea what you could do other than replace all the barrels. I guess the previous owner must have had the hatch barrel gum up (it happens very easily) and replaced it at some point.
Only two fixes I can think of are either to repin the trunk to match your key (which is what the locksmith quoted you for) or to buy an entire set of locks from a junkyard car, including the ignition and key. Better make sure you don't have a transponder key for the last option, though.
You're probably looking at at least $200 for all the parts from junkyards if you'd rather go the DIY route. I'd just look for a discount locksmith. Or figure out how to re-pin locks (I don't think it's easy, but hey, you'd learn a new skill!) |
Yaris TwoKeys
That's how grandpa's Chevy worked. Trunk key round and ignition/door key square. So you could select in the dark.
| Tags |
| door lock, key, locksmith |
| New remote key fob programming | costica | DIY / Maintenance / Service | 1 | 04-17-2016 09:02 PM |
| 2008 Toyota Yaris Immobilizer/Transponder Key | ItsanEE | DIY / Maintenance / Service | 0 | 07-11-2015 04:48 PM |
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 07:32 PM |
| Yaris key stopped unlocking manually or electronically - help! | southernyaris | DIY / Maintenance / Service | 1 | 06-13-2014 12:52 AM |
| Key fob locks but won't unlock | Pingouin | DIY / Maintenance / Service | 2 | 09-15-2010 04:53 PM |
