Old 12-26-2021, 09:35 PM   #1
Dec24th
Drives: '10 Yaris 3 door HB
Headlight Bulb & Rubber Cover.
Hi,
I needed to replace my headlight bulb. Before doing so, I watched a handful of YouTube videos to familiarize myself with the process. I tackled the passenger side headlight bulb today.
I unplugged the connector very easily.
The rubber cover, however, was really difficult.
I pulled and pulled, it wouldn't budge nor come off as easily as in the videos.
I moved on, to the metal tabs.
Minutes later, I managed to press the tabs to release the bulb. I find out that the bulb and the rubber cover are together, inseparable. It's like the bulb and rubber cover was one.
I replaced the bulb temporarily with a cheap LED. I will get a Halogen one eventually but how am I supposed to install the new one without a rubber cover? Common sense tells me to go to the auto-parts store and order the rubber cover with the bulbs.
My question to the forum is: Is that normal for the Rubber and bulb to be as one? There was no way I was able to get the rubber off the bulb at all.
Aa
Dec24th is offline   Reply With Quote
Old 12-26-2021, 11:05 PM   #2
Dec24th
Cancel the above post. I watched this video, and I just have to pry the rubber cover off.
https://youtu.be/uBYUh-ys92Q?t=302
Aa
9003, headlights, rubber cover
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 12:34 PM
Headlight bulb change....more to it than meets the eye... Yarflana DIY / Maintenance / Service 0 03-24-2013 09:56 PM
Where can I order a Headlight Bulb Rubber Boot online? JAM DIY / Maintenance / Service 2 12-08-2011 07:48 PM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 02:40 AM
How do you remove rubber headlight bulb cover? detroiter General Yaris / Vitz Discussion 2 01-18-2010 02:25 PM
