![]() ![]() Drives: 2014 Yaris LE Join Date: May 2016
3rd Gen Gauge Cluster Swap :D
Tired of not having a RPM gauge on your not manual Yaris?
Good News Everyone! I found a cost effective solution! Using the buying service Buyee I purchased a JDM Vitz gauge cluster off Yahoo Auction Japan to try and see if it would work in my 2014 LE with no tachometer. It was only $30 which is a fraction of the cost of a USDM gauge cluster on Ebay. Heres the good stuff, before and after! ![]() ![]() Pros: It was (semi) plug and play, both plugs are identical to the USDM cluster. took 2 minutes to install. Pull trim off with hands, unscrew two screws and then pop the gauge cluster forward, unclipping two clips on top with hand. Eliminates the TPMS Light if you have aftermarket rims Beeps and blinks the reverse symbol when in reverse for extra safety No matter what transmission you have (auto/manual) Every Yaris/Vitz gauge cluster has the readout for the gear you are in. It just doesn't show up when you have a manual car. (this gauge cluster is off a 5MT Vitz and my car is auto) If you're into the whole JDM hype thing this is a cheap cool swap to get those JDMYO! points ;D I personally am not. Cons: Mileage DOES NOT STAY THE SAME. I'm sure you will have to go to Toyota dealership to have a tech change it using tech stream or something. It's not a big deal for me, but if your concerned about your mileage you should track it then go down and geterdone. Bitch is only in KM but you can just remember 100Km/h is 60 MPH roughly Outside air temp doesn't read anymore, but the pin on the harness is in the exact same location on both cars, I think its a ECU issue with the Celsius Fahrenheit thing difference. Update: Just tried jumping a pin around on the harness and it looks like the diagram I got online was a little incorrect, the wire is switched on the Vitz cluster so you will need to re-pin that to get the ambient air temp to read, but it does read correctly once done. UPDATE: After driving it at night I found out the gauge cluster lights up when you turn the lights on, but the climate control and radio does not! Oh no! Will update again once I re-pin the harness. Enjoy! I hope this helps someone Last edited by KenTK808; 10-27-2016 at 04:46 AM. |
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
You said the odometer stayed the same? Doesn't seem that way since the KM would be higher than your mileage reading. Good to see that they swap though, I'll have to eventually find a USDM cluster with a tach for mine and swap it when the miles match up or have it reprogrammed to be correct.
-Karl the Uber/Lyft Driver |
Youre right! I cant do math. Good catch!
Cons the mileage is off lol |
#4 | |
I got bored and took the cluster apart just to see.
My findings are that there is a big hunk of plastic behind the gauge overlay, so NO you cannot swap a rpm gauge from another cluster in Some other interesting info is that the orange LED lights behind the cluster are soldered onto the board, so you also cant change the color of the lights. Just some extra info just in case anyone was wondering.
#6 | |
they dont manufacture the LE w/o sport Tacho Gauge anymore so im wondering if this stuff just bolts on :D? |
#7 | |
Good information, thank you for doing the legwork on it!
![]() ![]() Drives: Yaris 2014, Y. HSD 2013 Join Date: Feb 2013
Why you haven't took an UK speedometer? You have same specifications.
For information Toyota Ractis 2011 (Verso-s Euro model) have same plug and play connector on your Vitz - Yaris 2014. You need change front clear plastic. And keep back black plastic with clusters is the same as the Yaris. Make sure if it's CVT or MT and milage on odometer. https://www.partsplanet.eu/en/catalo...80052z71_7535/ |
#10 | |
やりすぎだ~
For the odometer to read correctly in miles, CTScott is the go-to-guy. Techstream won't be able to do it.
Here is his thread on that. link He also does LED color changes. He also has another thread here. On-the-fly KMH to MPH and back with the flick of a switch! Last edited by yarisugi; 10-28-2016 at 01:34 PM. |
#12 | |
![]() Drives: 2014 rental Join Date: Jun 2017
Bump. Any updates on the dash lighting issue after the swap?
I am looking for the parts # for the yaris instrument cluster USDM, does anyone have it so I can swap in the MT with the taco into my 2015.
also will the eco system still be retained/ all the lights and signals that the AT cluster does? |
found the cluster online, the temp reads in C everything else is in MPH.
photobucket doesnt display anymore can you make a more detailed diagram :C? |
Also I have entire toyota dealership service manual for the 3rd gen I can upload that tells you how to remove the gauge cluster and pretty much everything the yaris needs done to it, car is a 2013 but the model range is basically the same up till 2018. no sedan included just hatchback.
NCP131 |
#17 | |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 09:16 PM |
| 3rd gen 1zz tb swap | mr_miles | DIY / Maintenance / Service | 26 | 05-01-2013 09:20 AM |
| Gauge Cluster Swap Warranty? | superfly78209 | General Yaris / Vitz Discussion | 11 | 05-06-2012 09:43 PM |
| Successful Gauge Cluster Swap | kac | Cosmetic Modifications (Exterior/Interior) | 37 | 07-06-2010 09:05 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 04:32 AM |
