Old 04-24-2017, 05:19 AM   #1
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Blitz compressor install
The time has come to get Blitzed .
A friend offered to give his blitZ and I could not resist...
I am reading a lot of threads and try to do it once and right with all the knowledge aquired.
I have a complete setup with the clutch and fuel controler. I am only missing the switch selection plate for the compressor modes and the clutch on light.
What is your opinion for the 14point7 fuel controler?
Should I leave the stock one or go another way?
Thank you
ncp13 is offline   Reply With Quote
Old 04-27-2017, 03:36 AM   #2
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
The compressor was painted black which was coming off.. I had to clean it up with solvent wire brushes and a lot of patience .
Old 04-27-2017, 10:33 AM   #3
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Looks good! Can't wait to see it installed. I'm a big fan of Roots blowers for their nice linear power and ability to make a tiny displacement engine feel much bigger.
MugenRep is offline   Reply With Quote
Old 04-27-2017, 11:41 PM   #4
ecampos
ecampos's Avatar
Drives: 2017 Toyota Yaris S XP-150
Nice! I wish I could get one!
2017 Toyota Yaris S XP-150: K&N Cold Air Intake, Megan Racing MO-E Muffler, DNA Motoring Exhaust Headers, Pedal Commader throttle controller, NST Pulley Kit, STR 526 17x8.25 rims (Volk TE37 Replica).
ecampos is offline   Reply With Quote
Old 06-06-2017, 11:09 PM   #5
Lightrfire
Drives: 2007 Yaris hatch
I bought a spare switch from crankoldman. I'm not sure if he has more but it may be worth asking. Before I bought one from him Iwas considering a zen programmable throttle switch which would work the same.
Lightrfire is offline   Reply With Quote
Old 06-07-2017, 11:17 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's a bit of an old thread, but I'll add my 2 bits. I doubt I've got another complete switch setup, but I can look again.
I've got a diagram of the selector switch itself around here somewhere, but not the small box it connects to. The selector is just some resistors that change the voltage to a comparator circuit. The activation LED is tied to the output of the comparator, so it turns on whenever the throttle position signal goes above the threshold set by the selector switch. Sounds more complicated than it is. If you can solder, you can make your own switch out of whatever you've got handy.
Old 06-07-2017, 04:14 PM   #7
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Thank you all for the replies
I am just missing the graphics part of it . I have the switch itself .
I also made a 3mm teflon spacer - gasket for the intake manifold to keep away some heat from the all aluminum intake.
My kit has a boost gauge/ turbo timer setup but i really dont want to use it ...
Slowly getting there ,keeping it stock and ready for some 38c Greek summer driving ..
Everything else will be stock with the vehicle .. For now i guess
Old 08-29-2017, 12:45 PM   #8
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
What spark plugs do i have to run?
Old 08-29-2017, 03:31 PM   #9
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
IK22 are the correct heat range. The IK22 is a 7 heat range, which is what you want for a colder plug with a boosted application.
As for the gap, insufficient spark plug gap can cause pre-ignition, detonation, even engine damage. Too much gap can result in a higher rate of misfires, noticeable loss of power, plug fouling, and poor economy. With that being said first thing to do before you install the plugs is to check the gap to make sure its correct as it's not uncommon that they aren't properly gapped from the factory.
Old 08-29-2017, 03:51 PM   #10
DarkShadowFox
does anyone even have the supercharger for sale anymore? besides the 3k entry price :C
Old 08-29-2017, 03:57 PM   #11
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Try your hand at producing your own.
-Buy a Aisin AMR500 or AMR300, perhaps even a SC12 or SC14
-Remove AC and make a bracket that fits that area
-Play, experiment, fabricate and brainstorm
Old 08-29-2017, 04:02 PM   #12
DarkShadowFox
I have an idea of what I need, can you break me down a parts list I love DIY.
Old 08-29-2017, 04:03 PM   #13
DarkShadowFox
wow these are really cheap.
can I just relocated the AC compressor with a longer belt assembly or something custom?
Old 08-29-2017, 04:12 PM   #14
DarkShadowFox
I have kinda want to fab one of those overhead "Turbo 2000" intercoolers. like on the vios
Sent from my LG-H918 using Tapatalk
Old 08-29-2017, 04:31 PM   #15
DarkShadowFox
how do you feel about one of these with the
http://www.ecrater.com/p/23061250/91...id=81021731659
SC14? or the AMR500?
Old 08-29-2017, 07:35 PM   #16
MugenRep
MugenRep's Avatar
Drives: 2012 iQ
Every application is going to be different and it comes down to what you're capable of doing yourself or if not, farming out to a independent or friend.
I'd say this is a good sample list.....
- flat steel stock 8mm-12mm in thickness. This would be to make the bracket that helps to keep the supercharger secure.
- AMR300, AMR500, SC12, SC14, or even an Eaton m45 (I'd personally do a AMR500, albeit a little smaller than the Blitz Ogura TX12, it'd be easy to intercool).
- new injectors at minimum (1ZZ at minimum).
- some sort of A/F management (AEM FIC, Emanage Blue, CamCon c-101, etc.).
- input and output flanges for AMR300/AMR500 and piping for intercooler or not.
- bypass valve that recirculates.
- new serpentine belt since the AC clutched pulley is bigger than the supercharger pulley.
- MAF adapter possibly or intake and filter if not using stock airbox.
- Various other items to be thought up and engineered by yourself.
You'll have to get it and test fit it as well as take measurements and determine the easiest way to mount and run it.
*Make sure supercharger pulley is STRAIGHT and in line with other pulleys as this is the MOST IMPORTANT part to making it reliable and not causing it to shred belts left and right.
Top mount or side mount intercooler would work pretty easily and there are tons of tiny/inexpensive intercoolers out there. Go for it.
I'd do the AMR500 personally and then slowly work off from that adding parts as you go with test fitting and such. It may be even easier to go down to your local "PICK N' PART" to buy a spare 1NZ-FE and have that someplace to use as the item to test mount on. Should make everything a bit easier.
Old 08-29-2017, 08:57 PM   #17
DarkShadowFox
150 HP. little dependability interferance
Old 08-30-2017, 11:48 AM   #18
DarkShadowFox
so what ive read up on the AMR500 literally just looks like a bolt on job, is it oilless? purely just pump? cause in most of the installs looks like its just bolted on and hooked up to a pully.
EDIT: Looks like this is a supercharger that you have to oil but doesnt require an oil line, lots of really just bolting things up and getting a controller and some of the other parts that you had mentions, while were on that since this is going to be a bit of a step by step, are the 1zz injects just a swap in?
edit: is the flow rate of a 1zz injector 250? 1nzfe 210? AEM FIC piggyback and a lightweight pully system?
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 06:49 AM
2008 vitzRs clone+fixed pulley blitz... blacksandiegovitz Forced Induction Forum 5 12-05-2010 02:26 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 05:36 AM
BLITZ HAS CLOSED????? ROCKLAND TOYOTA General Yaris / Vitz Discussion 12 08-13-2009 06:35 AM
GI: OFFICIAL BLITZ YARIS laszlo Cars for Sale by private party 11 11-25-2008 06:05 AM
