Old 04-30-2007, 11:28 PM   #1
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
F5 Fujita Cold Air Intake Review
So I just installed my Fujita intake on my Liftback. The installation took longer than I thought since the fitment was tight to say the least. I'll list some quick pro's and con's to start with.
Pros
- Car sounds really sweet under full throttle, but isn't too loud while just cruising.
- Smoother power delivery and seems more peppy up top.
- Lots of extra goodies came with the intake.
Cons
- Squeezing the intake into place is kind of a PITA. I recommend having a friend help you.
- Car is LOUD under full throttle. This can good or bad, depending how you look at it.
- Threw a check engine light. I'll disconnect the battery overnight and see if that gets rid of it. If not, hopefully it'll go away after a week or so once the engine adjusts to the new air readings.
I gotta admit that the intake did have some fitment issues. I'll list them here.
Fitment Issues
- The bottom of the pipe where the filter connect is all kinds of weird, putting the filter on the back of the foglight housing, quite literally. I don't have fogs, but I fear for those that do.
- The small bracket that connects to the vibration reducer was facing the wrong direction. I had to bend it up in the general directionl, then hammer it down onto the rubber reducer thing to get it to fit. This took a majority of the installation time.
- The bottom of the pipe rubs against the splash guard infront of the wheel. I may be able to cut away part of the top of the splashguard without exposing the filter. I'll check it out later on when I have more time.
- The air circulation hose that goes from the intake to the engine is stretched to fit. It would have been nice if Fujita had supplied a slightly longer hose and better connectors.
- The sensor plug that is taken off the stock rubber piping really has no place to rest without clanking against the intake piping. I finally got around to taping it to another hose, but it's stretched a bit. Not enough to make me worry, but enough to mention.
__________________________________________
Overall, I'm pretty pleased with the intake. Some small fitment issues, but once all is said and done, the intake has made the car more fun so I figure it's worth the hassle. I would maybe ask Fujita to review the design to ensure that fitment for the both the sedan and liftback is the same, because I think they're somewhat different. I'll try to get some pics later.
Ran Kizama is offline   Reply With Quote
problem with cold air intake skc Canada 24 06-18-2007 08:34 PM
Fujita Cold Air Intake iheartmyyaris Performance Modifications 14 02-10-2007 02:03 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 05:25 PM
Cold Air Intake ? pegcityrs Performance Modifications 47 04-17-2006 08:43 AM
