![]() Drives: 2008 Toyota Yaris Join Date: Feb 2019
Transmission Control Cable Clips
I am in the middle of replacing the clutch on my 2008 by following the repair manual (https://cardiagn.com/2007-toyota-yar...r-manuals-pdf/). Does anyone know how to remove the "transmission control cable clips"? The ones with washers are super easy, I'm talking about the other two. Below is a link to a video with me showing them, and attached is the part of the repair manual I am trying to complete.
https://www.youtube.com/watch?v=x_2CuZDy87Q |
Closest thing I can find to someone removing these is the video below. I tried using a pry bar a little but it was smashing down on the cable and all the rubber parts around the cable so I didn't want to use much force.
https://www.youtube.com/watch?v=MA0mG8q8zvM Oh also I am aware of https://www.toyotanation.com/threads...clutch.489689/. I have really been mixing the two resources (that post and the repair manual). But either way, these shift cables need to come off. |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
You just need to grab the metal clip with a pair of pliers and pull them up. Can reinstall them by lightly taping them back down with a hammer.
This worked, just had to pull on it way harder than I thought I should be. I also tapped a flat head screwdriver in between them in between tugging on it. Thanks!
2ZR swap. DO IT! Ask how!
Yup, those are a pain to remove, especially if you live somewhere that uses salt on the roads. Vice grips or a big pair of channel-locks work best for me.
| DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation | CTScott | DIY / Maintenance / Service | 172 | 10-27-2025 02:04 PM |
| Werid Noise When I throw it into Reverse | LoudYar | General Yaris / Vitz Discussion | 12 | 10-26-2020 04:57 AM |
| Yaris Cruise Control Auto | evarkey | Performance Modifications | 1 | 07-02-2014 07:56 AM |
| 2009 Toyota Yaris OEM Cruise Control DIY | BentSpace | DIY / Maintenance / Service | 7 | 04-16-2014 09:05 PM |
