Old 04-08-2007, 07:03 PM   #1
LoudYar
LoudYar's Avatar
Drives: 2007 Toyota Yaris
Werid Noise When I throw it into Reverse
Hey guys,
When I put my Yaris into Reverse and turn the wheel fully in one direction, i get this weird rattling noise coming from the car, as well the steering wheel vibrates slightly.
Its only when the car is Reverse though.
Is there anything I should be concerned with? Or does anybody have this same sorta problem?
LoudYar is offline   Reply With Quote
Old 04-08-2007, 08:57 PM   #2
MrJester
Drives: homo
Manual or auto???
I have a manual and mine does make a slight noise seems like when I am letting off the clutch a little bit too much.
MrJester is offline   Reply With Quote
Old 04-09-2007, 07:40 PM   #3
LoudYar
LoudYar's Avatar
Originally Posted by MrJester View Post
Manual or auto???
Auto.
Its not a to loud, just makes enough noise to be a noticeable sound when the radio is turned off, and you can feel it in the wheel.
Old 04-10-2007, 07:19 PM   #4
Toyota Technician
Drives: 2007 Red Yaris LB MT
take it to ur dealer their is a tsb on this for auto's only.
Toyota Technician is offline   Reply With Quote
Old 05-11-2007, 03:12 PM   #5
iconcat
Drives: 2007 Yaris Sedan
Thanks for this info. I'm having the same strange rattling noise, too. Do you have a link for the TSB?
iconcat is offline   Reply With Quote
Old 05-12-2007, 11:53 PM   #6
Yaris
Yaris's Avatar
Drives: 2010 LB Meteor Metallic
AUTOMATIC TRANSMISSION
TSB2735
Technical Service
Bulletin
April 26, 2007
RATTLE NOISE FROM AUTOMATIC
TRANSMISSION CONTROL CABLE
ASSEMBLY IN REVERSE
Models:
‘07 Yaris (1NZ-FE, 4-Speed A/T)
Page 1 of 2
Title:
INTRODUCTION:
Some 2007 model year Yaris hatchback vehicles may exhibit a rattle noise from the engine compartment
above engine idle speed with the automatic transmission shift lever position in reverse. Follow the repair
procedure below to address this concern.
APPLICABLE VEHICLES:
• 2007 model year Yaris Hatchback vehicles equipped with the 1NZ-FE engine and 4-speed
automatic transaxle.
PARTS INFORMATION:
Previous Part Number Current Part Number Part Description Qty
90464-00748 Same Clamp 1
WARRANTY INFORMATION:
OPN Description Time OFP T1 T2
AT7004 Secure Clamp for Transmission Control Cable
Assembly 0.2 33820-5248# 91 57
Applicable Warranty*:
This repair is covered under the Powertrain Warranty. This warranty is in effect for 60 months or
100,000 kilometres, whichever occurs first, from the vehicle’s warranty registration date.
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
Page 2 of 2
RATTLE NOISE FROM AUTOMATIC TRANSMISSION CONTROL CABLE ASSEMBLY IN REVERSE TSB2735
REPAIR PROCEDURE:
1. Raise the vehicle and locate the No. 2 transmission control cable support to the left of the center
exhaust pipe flange.
2. Using the plastic clamp, secure the automatic transmission control cable assembly to the No. 2
transmission control cable support. Refer to the illustration for the location.
3. Confirm the repair.
NOTE:
Issue of this Technical Service Bulletin is to ensure that proper repair information is available.
IT DOES NOT CONSTITUTE AN AUTHORIZATION FOR REPAIR. Normal provisions of the formal
warranty policy, as applicable, will apply.
TRANSMISSION AUTOMATIQUE
TSB2735
Yaris is offline   Reply With Quote
Old 08-27-2015, 06:16 AM   #7
John Lenin
Drives: 2009 Toyota Yaris 3-Dr HB Auto
Performed this repair on my 2009 Yaris 2-Dr H/B (with Automatic Trans) yesterday ... used an ordinary plastic zip tie & fastened the Transmission Control Cable to the bracket noted in the TSB above ... did it from above, as I couldn't raise the car on the jack high enough to allow me to crawl underneath ... luckily I have small hands!
Took about 5 mins ... luckily no more rattle!
Secure cable to part 33829 in the diagram.
John Lenin is offline   Reply With Quote
Old 08-27-2015, 08:47 PM   #8
BLKHILLSGUY
Drives: 2011 3dr LB Polar White
Are the TSB's only good as you have a factory warranty, or are they for the life of the automobile?
BLKHILLSGUY is offline   Reply With Quote
Old 08-27-2015, 09:14 PM   #9
TSBs are in no way tied to warranty parrameters. A TSB, or Technical Service Bulliten, is an internal advisement issued by Toyota to its servicing network to alert its advisors of known issues causing servicing calls. It is for life, unless superseded by another TSB.
Old 08-27-2015, 09:15 PM   #10
BLKHILLSGUY
Thank You!!! I had no idea.
Old 06-29-2019, 12:26 PM   #11
jackfrank
jackfrank's Avatar
Drives: A black BMW
Manual or auto???
Thanks for giving a good idea. I have the same problem. ful
jackfrank is offline   Reply With Quote
Old 10-19-2020, 10:17 AM   #12
Darwin84020
Drives: 2007 Yaris, Hatchback
Hi,
Does anyone know where this clamp is for the part noted (33829).
I can not find the TSB, and am not sure were on the outside of the car this is.
I have this exact issue, one a 2007 with 150miles.
Out of warranty time.
Darwin84020 is offline   Reply With Quote
Old 10-26-2020, 04:57 AM   #13
Billiam
Drives: '10 White Yaris 4D LB
Just zip tie the cable to the bracket. That's been the fix for years
If you want to enjoy your car, stay off of the internet.
Funny noise when in Reverse sirshunted DIY / Maintenance / Service 21 07-07-2007 02:17 PM
2007 LB Auto-Trans NOISE in Reverse Pavel Olavich General Yaris / Vitz Discussion 4 03-22-2007 07:42 PM
Reverse Kaotic Lazagna General Yaris / Vitz Discussion 7 01-15-2007 03:03 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
Clicking noise in center console? devinlamothe General Yaris / Vitz Discussion 8 09-16-2006 11:03 AM
