Werid Noise When I throw it into Reverse
Hey guys,
When I put my Yaris into Reverse and turn the wheel fully in one direction, i get this weird rattling noise coming from the car, as well the steering wheel vibrates slightly. Its only when the car is Reverse though. Is there anything I should be concerned with? Or does anybody have this same sorta problem? |
Manual or auto???
I have a manual and mine does make a slight noise seems like when I am letting off the clutch a little bit too much. |
#3 | |
Its not a to loud, just makes enough noise to be a noticeable sound when the radio is turned off, and you can feel it in the wheel. |
![]() Drives: 2007 Red Yaris LB MT Join Date: Mar 2007
take it to ur dealer their is a tsb on this for auto's only.
![]() Drives: 2007 Yaris Sedan Join Date: May 2007
![]() ![]() Drives: 2010 LB Meteor Metallic Join Date: May 2006
AUTOMATIC TRANSMISSION
TSB2735 Technical Service Bulletin April 26, 2007 RATTLE NOISE FROM AUTOMATIC TRANSMISSION CONTROL CABLE ASSEMBLY IN REVERSE Models: ‘07 Yaris (1NZ-FE, 4-Speed A/T) Page 1 of 2 Title: INTRODUCTION: Some 2007 model year Yaris hatchback vehicles may exhibit a rattle noise from the engine compartment above engine idle speed with the automatic transmission shift lever position in reverse. Follow the repair procedure below to address this concern. APPLICABLE VEHICLES: • 2007 model year Yaris Hatchback vehicles equipped with the 1NZ-FE engine and 4-speed automatic transaxle. PARTS INFORMATION: Previous Part Number Current Part Number Part Description Qty 90464-00748 Same Clamp 1 WARRANTY INFORMATION: OPN Description Time OFP T1 T2 AT7004 Secure Clamp for Transmission Control Cable Assembly 0.2 33820-5248# 91 57 Applicable Warranty*: This repair is covered under the Powertrain Warranty. This warranty is in effect for 60 months or 100,000 kilometres, whichever occurs first, from the vehicle’s warranty registration date. * Warranty application is limited to correction of a problem based upon a customer’s specific complaint. Page 2 of 2 RATTLE NOISE FROM AUTOMATIC TRANSMISSION CONTROL CABLE ASSEMBLY IN REVERSE TSB2735 REPAIR PROCEDURE: 1. Raise the vehicle and locate the No. 2 transmission control cable support to the left of the center exhaust pipe flange. 2. Using the plastic clamp, secure the automatic transmission control cable assembly to the No. 2 transmission control cable support. Refer to the illustration for the location. 3. Confirm the repair. NOTE: Issue of this Technical Service Bulletin is to ensure that proper repair information is available. IT DOES NOT CONSTITUTE AN AUTHORIZATION FOR REPAIR. Normal provisions of the formal warranty policy, as applicable, will apply. TRANSMISSION AUTOMATIQUE TSB2735 |
![]() Drives: 2009 Toyota Yaris 3-Dr HB Auto Join Date: Jul 2012
Performed this repair on my 2009 Yaris 2-Dr H/B (with Automatic Trans) yesterday ... used an ordinary plastic zip tie & fastened the Transmission Control Cable to the bracket noted in the TSB above ... did it from above, as I couldn't raise the car on the jack high enough to allow me to crawl underneath ... luckily I have small hands!
Took about 5 mins ... luckily no more rattle! ![]() Secure cable to part 33829 in the diagram. Last edited by John Lenin; 08-27-2015 at 06:48 AM. |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
Are the TSB's only good as you have a factory warranty, or are they for the life of the automobile?
TSBs are in no way tied to warranty parrameters. A TSB, or Technical Service Bulliten, is an internal advisement issued by Toyota to its servicing network to alert its advisors of known issues causing servicing calls. It is for life, unless superseded by another TSB.
#10 | |
Thank You!!! I had no idea. |
Drives: A black BMW Join Date: Jun 2019
![]() Drives: 2007 Yaris, Hatchback Join Date: Jan 2009
Hi,
Does anyone know where this clamp is for the part noted (33829). I can not find the TSB, and am not sure were on the outside of the car this is. I have this exact issue, one a 2007 with 150miles. Out of warranty time. |
Just zip tie the cable to the bracket. That's been the fix for years
If you want to enjoy your car, stay off of the internet. |
| Funny noise when in Reverse | sirshunted | DIY / Maintenance / Service | 21 | 07-07-2007 02:17 PM |
| 2007 LB Auto-Trans NOISE in Reverse | Pavel Olavich | General Yaris / Vitz Discussion | 4 | 03-22-2007 07:42 PM |
| Reverse | Kaotic Lazagna | General Yaris / Vitz Discussion | 7 | 01-15-2007 03:03 PM |
| Reverse light vs Rear Fog light | cooldavidko | General Yaris / Vitz Discussion | 3 | 01-03-2007 03:09 AM |
| Clicking noise in center console? | devinlamothe | General Yaris / Vitz Discussion | 8 | 09-16-2006 11:03 AM |
