Old 05-27-2020, 08:17 PM   #1
Hjoken
Drives: 2013 Yaris LE 5 door hatchback
Voltage regulator or new Alternator?
My wife's 2013 Yaris is only charging at slightly above 12v. I had it tested and was told battery was fine but regulator in the alternator was bad.Has anyone taken one apart and replaced just the regulator? The car has 173k miles on it so i am thinking it would just be best to replace the entire unit.Or would it be ok to just replace the regulator? I have np taking it apart if so.
That being said,I am currently furloughed and trying to save where I can.Is there a brand suggested?
Thanks!
Hjoken is offline   Reply With Quote
Old 05-28-2020, 11:19 AM   #2
nortonfb
Drives: 2007
Try cleaning the voltage regulator.
You can try a re builder but the price maybe the same as a complete rebuild.
CT Scott was advertising a used one for $35 in the for sale section.
nortonfb is offline   Reply With Quote
Old 05-28-2020, 02:10 PM   #3
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Good advice by nortonfb. If it were me, I'd pick up CTScott's alternator. You can be guaranteed that, since it comes from him, it will be in great shape and fully functional. When my charging started failing, I had my voltage regulator out and could see the obvious corrosion that they are known for. I just replaced the unit with a CarQuest reman and it's worked flawlessly for years now. I think it might even have a limited lifetime warranty.
Old 05-28-2020, 03:14 PM   #4
Hjoken
Thanks.ill send him a PM
Alternator voltage Ramon1691 DIY / Maintenance / Service 5 11-20-2016 12:15 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
2003 Yaris High Alternator Voltage drcurzon DIY / Maintenance / Service 3 05-22-2012 05:16 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
possible alternator (voltage regulator) issue jesse1000 Canada 3 03-09-2009 10:10 PM
