Old 05-21-2012, 03:25 PM   #1
drcurzon
Drives: 2003 Yaris
2003 Yaris High Alternator Voltage
Hi There,
I have a 2003 Toyota Yaris.
The battery warning light is on on the dashboard, and the alternator is producing around 17v. I've had the alternator checked, and it seems to be okay.
The only things I can think of are that either:
- The regulator has failed in the alternator
- The car isn't telling the alternator to stop increasing voltage
There is a blue wire connecting to the alternator that I believe goes to the engine management connector, could it be that the wire between the alternator and ECU has broken?
Many thanks in advance, Daniel.
drcurzon is offline   Reply With Quote
Old 05-21-2012, 06:36 PM   #2
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
Mine did the same thing and the alternator regulator was bad. install a new alternator and your good to go.
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 05-22-2012, 02:29 PM   #3
Geoff Peace
Drives: Yaris 1.33 litre 2011
Originally Posted by drcurzon View Post
Hi There,
An alternator voltage of 17v is most certainly not OK. 13.6 to 14.4 volts is the regulated output. !7v could cause damage to other components. Needs to be checked by an electrician to establish the cause.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 05-22-2012, 04:16 PM   #4
BLH
Drives: 2007 Yaris Sedan
I would get it checked as soon as possible.
When I was fixing Motorola Two Way Radios. I had a similar situation. The voltage almost fried the low voltage high power transistors in the radio transmitter. It also was actually boiling the battery electrolyte.
2003, alternator, high, voltage, warning
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
2003 yaris MMT problems!! shuddering, rumbling feels like it wants to stall!!! mccracd Yaris TS Talk 1 01-10-2012 03:43 AM
