Old 05-10-2021, 04:13 PM   #1
stuf99
Drives: 1999 Toyota Yaris I 1.0i 16V
Front brakes not braking evenly
Hi
So I was at the state inspection yesterday and I was informed that my left front brake brakes 35% less than the right one. I was told that some lubrication of the brakes may do the job. But how do I check if this will do the trick? My first thought was to drive on a gravel road and brake hard, and then see of they brake at the same spot. I have tried it now before lubing, but I can't see that they brake unevenly, maybe its the ABS that interferes with this strategy...?
Anyone got other tricks up they sleeve?
stuf99 is offline   Reply With Quote
Old 05-10-2021, 07:37 PM   #2
ex-x-fire
Remove front wheels and push the caliper pistons in with a C clamp. They should go in with steady pressure. If not the piston might be sticky or might have a restricted brake hose. Pads should move freely in brackets, its common for them to rust in place. Caliper pin get frozen too.
Old 05-11-2021, 09:26 AM   #3
If you are not experiencing the car pulling to one side when braking then your caliper pistons are probably ok.
My money is on your caliper sliders (pins) seizing. This is usually the first thing to contribute to uneven pad wear. Without being regularly cleaned and lubed, they eventually dry out or gum up. When this happens, the pads do not return to a "floating" state over the surface of the rotor upon release of the brake pedal.
Old 05-11-2021, 01:20 PM   #4
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
In danish.
Det er 99% sikkert dine glidere der ikke kører som de skal.
Der er en fin video her på autodoc hvor de skiller dem ad, der må endelig ikke komme for meget fedt på gliderpindene.
Så komprimerer de fedtet inde i hullet og laver en fjedereffekt, så trykker den uens på klodserne.
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
brakes
Need front wheel alignment specs Rob888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-13-2023 11:00 AM
Bedding in brakes bairjo DIY / Maintenance / Service 6 04-01-2020 02:24 AM
2007 sedan front brakes job questions maui DIY / Maintenance / Service 11 09-28-2014 08:18 PM
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 12:04 PM
general service of brakes TriumphAnt DIY / Maintenance / Service 10 08-07-2010 02:20 PM
