Old 08-09-2021, 08:38 AM   #1
bluebearty
Drives: Beautiful blue Yaris 2006
Clutch bleed
Does anyone know the best Brake Fluid to use for a clutch bleed/refill?
My Yaris is 1L 2006 UK manual model.
I've only ever bled cars where they have a separate clutch and brake fluid fill cap/system. In the Yaris it's the same system. Do I just proceed as normal and the brake system won't be affected by the clutch bleed? Or must I bleed the brakes at the same time as the clutch if we only have one fill cap? :/
bluebearty is offline   Reply With Quote
Old 08-09-2021, 11:27 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Should be fine with standard brake fluid. The manual doesn't specify bleeding the brake system when replacing the clutch actuator cylinder nor does it specify bleeding the clutch when bleeding the brake system.
If it's never been flushed, probably a good idea to flush all the lines while you're at it.
Old 08-09-2021, 04:54 PM   #3
bluebearty
Cheers.
Does the order in which the four wheels have their brake fluid bled matter? Saw somewhere it had to be a specific order :/
Old 08-09-2021, 08:58 PM   #4
CrankyOldMan
Yes, start with the one farthest from the master cylinder, then work your way closer. The clutch is probably the shortest, or very close to the length of the driver's front wheel.
Old 08-09-2021, 10:17 PM   #5
bronsin
bronsin's Avatar
Bleeding the clutch will not affect the brakes. Use Dot Three or four fluid. Not.5
Old 08-10-2021, 08:48 AM   #6
bluebearty
Great, cheers guys!
I'm just trying to locate the clutch bleed valve in the engine bay.
Photo1 helps orient photo2:
photo1, engine bay: https://ibb.co/stzpqZf
photo2, clutch bleed nipple?: https://ibb.co/hDF0yvW
Is the circled part in photo2 indeed the clutch bleed valve?
Old 08-10-2021, 10:10 PM   #7
bronsin
bronsin's Avatar
That’s it
Old 08-11-2021, 11:17 AM   #8
bluebearty
That’s it
Thanks again
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Bleed the clutch today Tinkerman General Yaris / Vitz Discussion 4 06-20-2016 11:51 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
