Old 03-04-2016, 07:31 PM   #1
Aftermarket Clutch Q's
I have a question for those that have some experience with aftermarket clutches on their Yaris.
I'll be installing a lightweight flywheel and clutch sometime this summer and I'm trying to get an idea of what I should choose out of 2 options.
Option 1: Competition Clutch Lightweight flywheel sold with their stage 1 clutch. Cost: $499 USD
Option 2: Competition Clutch lightweight flywheel and an Exedy OEM Pro-kit clutch purchased separately. Combined cost: $400
I'd love to purchase the first option as they are matched perfectly and I know a stage 1 clutch can handle power/engage better. That said, I don't have money to burn so cost matters quite a bit. My question is, is a stage 1 clutch going to perform better than an Exedy pro-kit oem clutch, on a NA engine with a bunch of bolt ons, and is it worth an extra $100?
I don't ever plan to go boosted in my Yaris but I do like to drive very spiritedly and plan on doing some auto x this summer. I can't tell if I'm experiencing any clutch slip as I haven't built a boosted engine and truly felt it to know what it feels like. I could tell if I had clutch slip of a worn out clutch but this is not the case (my clutch seems to be in fine condition) although I'm not a fan of the Toyota oem clutch with its chatter and soft feel.
I can't help but feel a slight lag (slippage?) when I drop to 3rd gear and go WOT at 100km/h. I'm curious as to if it's worth the extra cash to go with a stage 1 clutch to improve the engagement during hard driving in a NA 1nz pushing a bit more than stock HP due to the bolt ons. Or is a stage 1 clutch a joke for those who are not boosted?
According to some other forums the Exedy oem pro-kit clutch is a bit of an improvement over the oem clutch but I don't believe it grabs any stronger.
FWIW I don't ever nor do I plan on doing clutch dumps.
Old 03-04-2016, 08:52 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got a stage 3 clutchmasters with my supercharger, and I wouldn't recommend anything less for a boosted application. The pedal feel was "much stiffer" than stock when I first got it, but I'm used to it now and it feels like stock. If you have any notions of adding power in the future, save yourself the hassle of pulling the trans a second time and go stage 3.
That said, I have no experience with stage 1 or 2. =)
Old 03-04-2016, 09:08 PM   #3
Jason@SportsCar
Dont spend the $20 on the swaybar bushings and put it towards your clutch - then the good one is only $80 more.
Old 03-04-2016, 09:41 PM   #4
hehehe, already scrapped the bushings after your advice, put it towards a sandwich plate for my oil gauges in a couple months.
Is there still a benefit to be had with a stage 1 clutch over oem in a NA engine? I won't be getting any more power out of my engine as I'm not going boosted and I've pretty much done everything I can to gsqueeze out as much power as possible with bolt ons. Other than a camcon down the road I don't think I can do much else. That said I'm happy with the power/reliability balance with this being my DD and a hopefully weekend autox'er
Old 03-05-2016, 05:00 AM   #5
KTS
KTS's Avatar
Drives: Vitz RS
If you have no problem with the feel of the OEM clutch then leave it alone. If you decide to change the clutch install an aftermarket flywheel one time as you drop the gearbox. I personally didn't like the feel of the OEM clutch and I had plans for boost (blitz s/c currently installed) therefore I change the clutch setup.
KTS is offline   Reply With Quote
Old 03-05-2016, 04:33 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I won't ever buy anything from Competition Clutch again. They are a shit company. They do not honor their word nor their parts that fail.
Other than clutch masters check out the ACT TS6-SPSS.
Sent from m-o-b-i-l-e
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
WHERE CAN I FIND AFTERMARKET CLUTCH KIT FOR 1SZFE Attitude Forced Induction Forum 0 01-21-2011 04:44 PM
