ringmeister
Drives: YARIS 1.5 Join Date: Mar 2007
Track Virgin No more.
Finally. Some track time.
Dunlop Sport Maxx tyres I was running was phenomenal. Extremely good grip in the dry. The Yaris was extremely grippy, but on the track, I wished for coilovers rather than NF210s I'm running. Way too soft. Harder shocks and springs would have made the car corner flatter and more predictably. The balance of the car was quite neutral, the rear felt very planted, no fears for oversteer at all. The engine, was pathetic. As expected. Definitely needing more power. ![]() ![]() Pictures courtesy of Leong.
![]() ![]() ![]() ![]() ![]() Drives: 2007 Yaris HB Join Date: Apr 2007
Hee! I can see your co-pilot gripping the "oh shit handle" pretty tight
must have been a big corner coming up...So you don't like the NF210's for this purpose? Those are the ones I have been planning to get, but I would be auto-x only, no high speed tracks... also I'm wondering if you have sway bar on there... |
Parallel Parking Pro
I think its a pretty well-established fact that lowering springs are mostly aesthetic improvements and less about handling improvements. They don't change the damping rate of the shocks to cope with bumps of higher speed and frequency like a set of coilovers can.
It can get rather choppy in the bends when the car starts hopping sideways over undulations. The car felt neutral and balanced because you weren't going fast enough, Marc.
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I know what you mean. Toyota put a 1.5L engine in there when all we really needed was 700-750cc. Our efficiency isn't what it could and should be because of this.
For what? It only takes 1 humanpower to pick up groceries. ;)
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#5 | |
#7 | |
But then again, all we really need is an oxcart to get around. Or better yet, since we've evolved legs and feet, we should all be just walking and running around. If you're talking about need, a human being needs very little, just air, water, shelter and food. All the rest are wants. |
Yes I forgot about that. You will get a lower CG, the lowered springs are stiffer so they'll also resist roll a little better.
Good point! Well if you are ever in my neighborhood and change your mind...
I know right?
Very cool. I've thought about taking mine to a road course just for kicks.
-Kev 07 Bayou Blue Liftback 5-spd manual |
cool. i want to run on a track...=\
![]() Drives: Yaris S Join Date: Jun 2007
Even with a lower centre of gravity, the roadholding would not be so great with just lowering springs. The damping rate of the stock shock absorbers may not match the new springs resulting in choppiness. Still, unless you truly intend to keep adjusting your suspension settings every month or so, coilovers may be overkill due to the high price.
Cleong, SG club running in Pasir Gudang? |
Yup, this coming weekend, just trying out our cars (we know that they're slow).
But at least it validates some of the mods that have been performed on each car as compared to stock.Some of us should be there, maybe around 5 or 6 Yaris. A mix of autos and manuals is possible, and there should be a JDM Vitz 1.3 also. |
ringmeister
I beg to differ when cleong says.... springs are only meant for aesthetics.
I love my NF210s on the road. Its supple enough, yet... it gives me alot better handling compared to stock. Turn in improves, car feels so much more direct. I wouldnt even go near the track with stock suspension. THe NFs are pretty soft, so the stock dampers does an acceptable job calming things down. I love to take the NFs over undulating country roads with real world ridges, bumps and what have you. However, if you're installing stiff springs on stock dampers, it would feel crappy. I have driven cars which felt like they have no damping because of the springs. CHoppy. Harsh. On the track however, G forces are consistently high over sustained periods. That is when I felt I needed stiffer dampers and springs. But seriously, how often do I drive on the track ? You may get 2 second faster lap times for the occasional track session, but I believe it will rattle the shit out of you on a poorly maintained roads. IN fact, you'll probably be so much slower on the road... trying to avoid bumps, manholes, etc etc. I think the NFs and stock dampers are good for the road, realist |
#18 | |
). Right now I thinking I will replace springs, then shocks, then maybe add rear sway once I see how much more body roll I want to dial out. |
| Yes, I can finally post here! (Confessions of a track newbie) | cleong | Tracking, Racing, Auto-X Forum | 12 | 10-20-2008 12:43 PM |
| Yaris Track Review | 03Z33 | General Yaris / Vitz Discussion | 42 | 09-23-2007 01:35 PM |
| Willow Springs Track Day This Sunday! | 03Z33 | California | 4 | 09-23-2007 01:34 PM |
| drove a SLR McLaren at the track yesterday | rage2 | Off-topic / Other Cars / Everything else Discussions | 18 | 06-15-2007 04:37 PM |
| Streets Of Willow track day - Non Yaris Warning. | largeorangefont | Photo-Video-Media Gallery | 23 | 06-03-2007 09:03 PM |
