Old 06-02-2022, 05:29 PM   #1
lightdisc2
Drives: Yaris 2008
Lug Nut / Wheel Fitment Advice
I am trying to install Circuit Performance 15 x 6.5 alloys on my 2008 Hatchback. They didn't fit because of the center bore. I ordered aluminum Hub Centric Rings 73.1mm outer and 54.1mm inner. Is that all I will need now for a snug fit? Or will they also need aftermarket lug nuts? I have the stock lug nuts that are used for the steelies at the moment and would like to use those if possible. Thanks for the advice.
lightdisc2 is offline   Reply With Quote
Old 06-02-2022, 05:55 PM   #2
lightdisc2
Drives: Yaris 2008
Update: The wheel manufacturer recommended me some specific ones that I just ordered. Will update again when I try to install them.
Old 06-02-2022, 05:56 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Get aftermarket lug nuts.
Tuner lug nuts more specifically.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 06-03-2022, 03:47 PM   #4
sh0rtlife
typicaly speaking steel wheel nuts will useualy have a different taper to mag nuts, but its not always the case and can vary wheel to wheel, if the wheels have a steel cone in them they are often made to use a steel wheel nut, if they are raw coned aluminum then they useualy need a wide flange mag nut
but everything changes wheel to wheel manufacturer to manufacturer...more often than not you cant even take their word for it and need to check once you have the wheels in hand
Tags
centric ring, hub bore, lug nuts
Wheel Fitment Database DuckinOut Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 11-13-2008 03:07 PM
Wheel Advice caveatipse Cosmetic Modifications (Exterior/Interior) 8 09-19-2007 03:39 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
lug nut spacing thatboyjer Wheels, Tires and Suspension Forum sponsored by The Tire Rack 34 07-13-2007 01:45 PM
Wheel fitment? PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-26-2007 01:18 PM
