Old 02-26-2007, 01:01 AM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Wheel fitment?
I have been searching for wheels and have found not every online seller lists the Yaris or has limited wheels available for it compared to an Echo or Scion XA.
My questions are:
1. As far as fitment, shouldn't the Echo, Scion XA/XB, and Yaris all have identical fitment?
2. Are there any differences as far as hub diameter, lug nuts required, off-set spacing, etc.?
3. Could I search and buy wheels for an 05' Echo and assume they will work on my Yaris(provided tire size is correct)?
Thanks in advance for your help!
Old 02-26-2007, 10:11 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Echo no, Scion XA, yes, XB no offsets are everso slightly different.... just look for 4x100 bolt pattern with a +35-42 offset should do ya fine
Old 02-26-2007, 11:14 AM   #3
PetersRedYaris
So a 17x7 with 38mm off-set will work? Tire rack says it won't fit and recommends a 17x7 with 45mm off-set. I worked out the dimentions and a 38 mm off-set will only stick out about an extra 1/4 inch.
Old 02-26-2007, 12:18 PM   #4
dansides
dansides's Avatar
Drives: 07 3 dr
is that the wheel sticks out a 1/4= are the tire if only the wheel the tire will proturde out passed that 1/4'' how much ?
dansides is offline   Reply With Quote
Mesh Steering Wheel Cover... Toxic? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 20 07-03-2010 05:53 AM
PIMP Wheel for the yaris EnduroMTS Sponsors Classifieds Area 32 11-06-2006 05:23 PM
20" wheel question mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-25-2006 11:22 PM
Xa - Yaris steering wheel jcove Cosmetic Modifications (Exterior/Interior) 1 05-09-2006 08:04 PM
Yaris wheel sizes and XA (ist) wheel sizes Master General Yaris / Vitz Discussion 10 04-18-2006 11:38 AM
