![]() Drives: 2004 echo Join Date: Jun 2018
brake pad rotor replacement
Good day, I am planning to change the brake pads and rotors myself. To make the job easy, I would like to know how to turn the steering wheel to one side with only one wheel jacked up. I have 1 scissor jack and 4 jack stands. Thanks.
Can you post a picture?
if you have 4 jack stands then jack up the front half of the car...turning the wheel while only up on a scisor jack is not advised, nor is it if you have a single jack stand under the car
you can jack up the entire front half of the car off of the transmission front center of the car |
Thank you for your suggestion. I cannot find the jack point to lift the front half. I can borrow a floor jack from a friend.
look under the front and youll see a flange between the oil pan and the trans oil pan jack there its the spot ive been using for a decade+ now....i use my trailer hitch to do the rear half
| Tags |
| brake pad rotor jack |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| "Thunk" sound after caliper and brake pad replacement | Hamster | DIY / Maintenance / Service | 3 | 08-22-2020 11:34 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 09:05 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 08:34 PM |
| SS Brake Line + Brake Pad + Rotor Installed~ | AlainMikli | Performance Modifications | 45 | 03-20-2010 11:55 PM |
