01-07-2023, 04:03 PM | #1 |
Drives: 2007 1.3vvti Yaris Join Date: Jan 2023
Anti sway bar
Can anyone tell me if a rear anti sway bar is worth it on a 2007 1.3vvti? If so does anyone know where to get one that fits
01-07-2023, 04:55 PM | #2 |
Drives: yaris Join Date: Nov 2018
Yes its worth it, you will feel a difference. You will need to get 4x 10.5 Graded bolts if they don't come with the sway bar. Any shop will be able to install it, it's a very simple install with just lining it up and securing it with 4 bolts.
01-07-2023, 05:01 PM | #3 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
it really depends on a few factors
how hard do you drive? do you like to carve corners and maintain speed or do you slow down? what size tire are you running? all said i think its going to be great improvement, HOWEVER unless your driving hard enough on grippy tires to FEEL the rear of the body lift and start rolling on the corners your just adding weight i still dont have one.,,but last summer after the brake work and the swap to grippier tires ive found corners where i can FEEL the rear flex and lift....and i see 3 that can be ordered up toss 100-200lbs in the back seat, go for a drive in the twisties, remove the weight and go do it again and if you cant feel the change in how the rear acts you dont need a sway bar..if you can feel it..you need one |
01-07-2023, 06:02 PM | #4 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Yes its worth it, it makes a positive difference in every way regardless on how you drive. It should have been standard equipment on these cars.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
01-08-2023, 03:35 AM | #5 | |
01-08-2023, 06:58 PM | #6 |
if you drive a lil hard then yes by all means toss one on, i think the 2 most readily availible are "whiteline" and TRD
02-16-2023, 07:57 PM | #7 |
Drives: '09 Yaris carmine red 2d HB Join Date: Jun 2009
You will definitely feel the difference. I installed one on my '09.
It really transforms the handling for the better You would not think it would with the non independent solid rear axle but, it does. BTW, there area few different vendors that sell their version of this sway bar. Just get one that is made to fit your year Yaris Once you get one, it is a fairly easy install Last edited by RedRide; 03-29-2023 at 06:37 PM. |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 05:25 AM |
xA or xD front sway bar fit in to 07 Yaris | yariseggvvti | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-29-2012 09:47 PM |
rear anti sway bar = better mileage? | Lewis | Fuel Economy Forum | 42 | 12-04-2009 10:42 AM |
solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
Best place to purchase a Tanabe strut bar and or TRD Rear anti sway bar? | thomasward00 | General Yaris / Vitz Discussion | 3 | 07-12-2007 01:22 AM |
