![]() ![]() Drives: 07 Yaris 3DR Join Date: Apr 2007
Hub Assembly or Wheel Speed Sensor?
Hi all,
in 2022, I had an ABS fault on my 2007 Yaris. I used a computer scanner which told me there was a fault with the rear wheel speed sensor, rendering the ABS system inactive. I and ordered a rear wheel hub with built in ABS wheel speed sensor for around $50 CAD from Rock Auto. I took a gamble and replaced the rear-right wheel hub assembly, since the computer doesn't report WHICH ONE is faulty. Just that it is in the rear. Cleaned out the electrical connections with some cleaner and re-assembled. This cleared the issue. Yay! Well, now I have the ABS fault again. Looking on Rock Auto, I'm seeing the complete hub assemblies, but also a standalone wheel speed sensor part. It's my understanding that the wheel hub and wheel speed sensor are a complete unit. That you can't detach the speed sensor itself and replace it. Is that true? There's a basic listing of just the sensor here, as well as a wheel hub assembly that I have purchased in the past. https://shorturl.at/Enjqz For the whole hub assembly that I've purchased before https://shorturl.at/U2znV So my question is. Can I just buy the sensor and replace it? I was under the impression that I couldn't. |
| Vehicle Speed Sensor Problems | jacl3 | DIY / Maintenance / Service | 1 | 06-23-2025 01:16 AM |
| 2007 Yaris Speed sensor Harness 90980 11143 | Ben_davis | General Yaris / Vitz Discussion | 4 | 04-01-2017 05:00 PM |
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| 2nz-fe speed sensor help | trupial | DIY / Maintenance / Service | 2 | 06-11-2015 09:12 PM |
| Fix for Broken Speed Sensor Wire? | BentSpace | DIY / Maintenance / Service | 13 | 06-02-2015 07:04 PM |
