#1 |
Newbie
Drives: 08 Yaris, 07 Versa, 97 Maxima Join Date: Mar 2011
Vehicle Speed Sensor Problems
I am having a problem with the car (08 Yaris) where the speedometer needle is jumping up and down, it has been getting progressively worse and sometimes when it happens the transmission begins shifting erratically.
There is no check engine light on. There seem to be 2 sensors related to this, 1) The vehicle speed sensor and the revolution sensor ![]() And 2)The revolution sensor is the black plastic one ![]() The second one pretty much directly under the battery. I can get that one out no problem, but the speed sensor is a little further back (closer to the firewall and center) and has the 3 wire connector, I can get the connector off, and I can get the bolt out no problem, but I can not for the life of me get the sensor out. 2 questions really for you guys, do you think this sensor is the problem? And do you have any tips to get it out? I see on ebay I can get the parts pretty cheap, but here in Canada the only places I can find them want 130 for the Revolution Sensor and 180 for the VSS so it's pretty expensive to diagnose this way. |
![]() Drives: Yaris 2008 Join Date: Jan 2022
Bumping this thread I am having the same problem
| Vehicle Speed Sensor | Brand | General Yaris / Vitz Discussion | 16 | 01-19-2016 12:11 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Inlet air temp vs. vehicle speed | LtNoogie | Performance Modifications | 8 | 04-27-2009 12:20 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| problem car | conurebuddy | General Yaris / Vitz Discussion | 23 | 04-11-2009 12:37 AM |
