Cobra
Drives: '07 3-door Join Date: Jan 2007
Leg Room
Has anyone figured out how to make the drivers side seat go back a little further for some added leg room? I have a '07 3-door and would like to sit back from the pedals a little further. Thanks, Chris
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
I'm 6'3" and with the seat all the way back I got plenty of room
come on guys let's see some serious answers
![]() Once you go as far back as the stock sliding system will allow, there's not a lot of options, the only thing I can think about is going to a metalworking shop and asking them to offset the seat frame back a few inches. It won't be easy, it probably won't be pretty, but it will work. But then, due to the car's steering wheel position, won't you feel lie you are reaching way too much to grab the wheel?
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
before doing it, make sure the steering wheel won't stay too far from your hands
push the seat in front then look on the seat rails (in the rear of the seat), there are two metallic clips bent upwards- this stops the seat from moving backward. you might try to bend this down. also check the wires under the seat as there is a seat position switch connected with the airbag (depending on how far the seat is from the steering wheel , the airbag deploys later or earlier). |
![]() ![]() ![]() ![]() Drives: 07 Yaris LB Absolute RED Join Date: Apr 2007
i hear an e-fight coming soon
v |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
hey. have you ever worked with metal? if not a fab shop can help you. one thing you can do without lenthening the sliders or anything that extreme is pull the seat out and make some brackets for where it bolts to the floor. if you make a steel bracket to take the place of the stock one you can just lenthen where it blots to the floor. no redrilling of the floor boards, reversable, and cheaper. just pull the seat out and have a shop make a metal mounting plate that bolts to the floor but has more lenth facing the rear of the car the seat still blots down, just to a piece of steel the eventually bolts to the floor. all you should need is a piece of flat steel with a hole on one end and a bolt welded to the other end...make 4 of those and you are set. might need a cross brace between them, but you get the idea.
no permanent marring of the seat brackets, fab shop or you can take care of it, and the seat moves back further. P.S. to all the jack offs...if you have nothing usefull to say do us all a favor and shut your trap...it will make this site more enjoyable.
what the heck did I miss? seems like there are some deleted posts!
Don't Milk the Cat! -Said by me during a game of Cranium.
Cobra
I believe my point has been proven!
brick, have you been smoking again ?
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
If you modify the stock bracket you risk having it break in a serious accident.
You might be able to get an aftermarket slider assembly to work. I'm 5'11" and my legs where always in an uncomfortable position when driving. I didn't think much of it until I got a new car and now it feels like I am driving in a Lazy-Boy.
ChinoCharles Intake supporter. |
![]() ![]() ![]() Drives: 07' Yaris Liftback - silver Join Date: May 2006
| front seat room | Bigdaddy727705 | General Yaris / Vitz Discussion | 9 | 10-30-2013 11:26 AM |
| Yaris's room in the rear? | feddup | New YARIS Purchase Forum | 8 | 07-18-2007 11:44 PM |
| Yaris chat room.... | jdubau55 | Off-topic / Other Cars / Everything else Discussions | 9 | 03-06-2007 08:37 PM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 07:19 AM |
| ok so weve discussed the interior room on... | p2filz | General Yaris / Vitz Discussion | 5 | 03-16-2006 07:54 PM |
