Old 02-15-2006, 07:30 AM   #1
nwdixieboy
Drives: ecoh
Power Windows Leg Room
Has anyone sat in a Yari with Power Windows and does the extra gear detract from your side knee room much? I have an Echo with manual windows and I find it gives me more legroom than I find in the Scion with Power Windows?
nwdixieboy is offline   Reply With Quote
Old 02-15-2006, 09:21 AM   #2
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
Well, Echo and Scion are different cars, you cannot compare the two for leg room by that. From my experience, the door panel is the same for w/ P/W and w/o.
GabL is offline   Reply With Quote
Old 02-15-2006, 10:33 AM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
While the Echo and Scion are different cars above, the are very similar underneath.
However the Yaris is completely different underneath and above then both of them.
Old 02-15-2006, 09:43 PM   #4
as400g33k
as400g33k's Avatar
Drives: 05 YRS Silver Lining Metallic
well the yaris is longer, wider and taller than the echo it precedes. so it has a bigger cabin room than before. that said, go to a dealer and try it out yourself.
as400g33k is offline   Reply With Quote
Old 02-15-2006, 11:57 PM   #5
swng
swng's Avatar
Drives: 06 3-dr auto RS
FYI, I have powered windows and I do not feel any lack of side knee room. The electric gears do not seem to make their presence obvious.
swng is offline   Reply With Quote
Old 02-20-2006, 09:01 PM   #6
NickNickNick
Drives: 06 Silver Yaris 3-door Manual
There is no problem in leg room. I drove a Yaris without power windows for about 2 weeks, and never noticed a difference when I got my car with power everything.
NickNickNick is offline   Reply With Quote
Old 02-22-2006, 05:32 PM   #7
GabL
I want JDM bumpers!
GabL's Avatar
As I mention, the door panel should be the same for power and non powered version. They won't invest $500K just to get a die to make door panel for the non-power window version. They'll make sure the non power-window and the power window both fit to the same place!
Old 04-05-2006, 10:56 PM   #8
nwdixieboy
Drives: ecoh
I just sat in a new US Yaris with power windows after buying one without it. I am so glad that I did. The power window unit sticks out about 3 inches and greatly reduces the lateral leg room IMHO. In the non power version there is actually an indentation into the door frame to give you extra room.
Old 04-05-2006, 11:05 PM   #9
swng
swng's Avatar
Interesting! In this case, may be a picture is worth a thousand words.
Old 04-06-2006, 07:19 AM   #10
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
IMO, the power window version should actually have more room, but they'll probably be very close to the same space (with the exception of the Handle)
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
rear corner windows fogging wushumasterku General Yaris / Vitz Discussion 14 01-23-2006 03:09 PM
